91 hatch b18... idle problem...
Old Apr 4, 2008 | 06:06 AM
cowboys22cardinals22's Avatar
* B A N N E D *
Default 91 hatch b18... idle problem...
i know this is a pretty common problem but i cant seem to squash it... it idles high then low... i have a b18a with a b18b manifold... which is like 3 vaccum lines and ive done diffrent things of switching them around and it still idles retarded... any body got any ideas... its killing me
Old Apr 4, 2008 | 06:14 AM
shortyz21's Avatar
Default Re: 91 hatch b18... idle problem... (cowboys22cardinals22)
check the FITV..
check your iacv...
just search for both of those on here and u will find oodles of info
Old Apr 4, 2008 | 06:15 AM
91siBoost's Avatar
i've had a problem like this b4 a couple time on different cars, if u check all vacuum lines and they are ok...put ur fing over the bypass air holes in the throttle body..most likely its ur fast idle valve in the bottom of the throttle body...but while the car is running put ur finger over one of the holes at a time and if it idles out then thats ur problem!
Old Apr 4, 2008 | 06:31 AM
* B A N N E D *
Default Re: 91 hatch b18... idle problem... (91siBoost)
okay guys thanks for the quick response will try tonight if it stops raining here...
Old Apr 7, 2008 | 09:00 AM
* B A N N E D *
OKAY... PUT MY THUMB OVER THE bypass air hole and it idled fine... a little high but i can bring that down... so since i think its the fitv what do i have to do replace it or just clean it... or what do i do to get this problem resolved...
Old Apr 8, 2008 | 06:13 AM
* B A N N E D *
I PULLED the fitv off last night and found like this blue almost like a ballon shreads in the end of it... so im kind of wondering if thats what would cause my idle to be stupid... if its not... what am i suppose to do by meaning you say "check it" what exactly am i looking for? clean it up... it looks pretty clean inside as it is...
landon2992
Dec 27, 2009 10:01 PM
ilovemyh22
May 6, 2009 12:54 PM
tylertocker
Apr 20, 2008 01:06 PM
del soler
Sep 10, 2004 02:06 PM
h-bomb
May 20, 2004 05:33 AM
