Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Panasport C8 backspace
Old Apr 4, 2008 | 04:56 AM
DrSeuss's Avatar
Default Panasport C8 backspace
I'm thinking about purchasing some used 13x8.5 Panasport C8 rims to get ready for my jump to r-comps. They're off a Miata and have a 5.5" backspace. Does that translate to a +32 offset (8.5/2 - 5.5)/25.4? Right now I'm running Enkei RPF-1 15x7 with a +41 offset. I've swapped the brakes out for GSR front and rear calipers but I'm pretty sure that these rims will clear the caliper. Does anybody have any fitment experience with these rims on a 93 Civic HB? Is a 5" backspace better or can I just use spacers with longer studs?
Thanks
Old Apr 4, 2008 | 08:17 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Panasport C8 backspace (DrSeuss)
If they are 8.5" wide (between the beads) then the overall outer-edge-to-outer-edge width (where the backspace is measured from) will be about 9.5", so (5.5 - 9.5/2)*25.4 gives an offset of about +19mm. No experience with your fitment, but that is the approximate offset from the info given.
Old Apr 4, 2008 | 02:33 PM
13inches's Avatar
My understanding is that Hondas and VWs use little less backspacing than Miatas in wide 13" fitments. Something more in the range of 4.5" - 5".
Would you mind posting a link to the wheels for sale? I'd be very interested if you decided to pass. Yes, I have a Miata.
Thanks!
G_seven
Acura TSX
May 8, 2008 09:18 AM
civicVI
Acura TSX
Aug 19, 2007 10:28 AM
crx.com
Jul 19, 2006 06:44 PM
Shft@9GSR
Aug 6, 2003 09:34 AM
jdm jedi
Jun 6, 2003 05:02 PM
