Install question for those with ITR optional OEM side skirts and rear valances
I got some used OEM ITR side skirts and rear valances for my R and they didnt come with all the hardware. I was wondering if anybody had the Template for the rear valances. What is the differance between the expansion clips that come with the optional side skirts and the ones that come stock with the side sill panel. The instructions say to discard the stock ones. Can I get the hardware that came with the rear valances from the dealer or should I Home Depot it. I need the (2) square-head bolts, (2) adhesive washers, (4) spring nuts, (4) self tapping screws, (4) washer bolts, (2) cap nuts but what size? I was wondering if anybody else has done a McGuyver on these.
For the sideskirts you can use the hardware from the old sideskirts. That's what I did. As for the rear valances, I had the hardware, but the mounting points were screwed up so I just screwed it in and put the screws were you could not see them.
First off, the oem kit was not made specifically for the type r, so its not "ITR optional OEM sides and rears" like you mentioned...but anyway...
basically what blackfire said, the skirts can be mounted with the old hardware that you remove off the stock sides. As for the rears, the template can be sound using the SEARCH button.
Just print it out, cut it, and go from there. I used the printout and made a custom metal plate to make mounting easier for me.
The dealer has the hardware i believe, But you might as well go to home depot, it will be much cheaper and essentially its the same stuff.
XANTHODC2R
Apr 4, 2008 03:32 PM
XANTHODC2R
Feb 21, 2008 03:10 PM
