GSR Apexi N1 exhaust on LS
Old Jul 10, 2002 | 11:08 AM
2lowintegra's Avatar
Default GSR Apexi N1 exhaust on LS
i currently have a 2.25" 5zigen fireball cat back exhaust... it is axle back with a cheapo 2.25 mid section...
my question is... if i buy an Apexi N1 axle back muffler which was on a GSR will it..
A) fit my car at all since it's for a GSR and i have an LS?
B) fit my car but require a different midsection since they are two different sizes?
C) bolt right up to my existing midsection?
i'm kinda lost on this one...thanx
Old Jul 10, 2002 | 11:10 AM
junglistgsr's Avatar
Default Re: GSR Apexi N1 exhaust on LS (toolowintegra)
an axleback is not model dependent. the "mid-section" is the pipe that changes from different models...but if you have one that fits your car already any axleback for a G3 integra should in theory bolt right up to it. just make sure the bolts on the flanges are in the same locations....
Old Jul 10, 2002 | 11:18 AM
Default Re: GSR Apexi N1 exhaust on LS (junglistgsr)
oh ok, so it's just the mid section that is different between the LS and GSR.... but since i have a mid section, the axle back muff should bolt right up....?
ok, and since my midsection is 2.25" and the axle back is 2.5" i probably have to change my midsection to a 2.5"?.
[Modified by toolowintegra, 8:19 PM 7/10/2002]
Old Jul 10, 2002 | 11:19 AM
that would be ideal, or get a flange welded in that increases the diameter so that you dont have a big bottleneck.
Old Jul 10, 2002 | 11:22 AM
ok thanx a lot.... i needed a definite answer on this because i am probably going to buy advancxgsr's Apexi axle back muff. but he has a gsr and i have an ls... just wanted to make sure it would fit... wouldn't want to get it all the way here only for it not to fit
Old Jul 10, 2002 | 11:24 AM
as far as I know what I said is true....
but forgot one thing, make sure they are both for 2 doors or both for 4 doors.
fergs96integra
Jul 23, 2008 06:31 PM
jdmmugeneg6
May 13, 2004 10:56 AM
hatchMASTR
Oct 16, 2003 07:09 AM
SubTitle
Sep 21, 2003 05:55 PM
LillDragun
Jul 15, 2002 09:50 PM
