Why Do People CUT ECU wires? Now I'm screwed!
Old Apr 3, 2008 | 07:11 PM
gus straussen's Avatar
Default Why Do People CUT ECU wires? Now I'm screwed!
I got this 94 del sol that some moron jacked the ECU out of and cut off the connectors to it.
Fortunatley I have a donor del sol that I am able to cut the connectors off from.
Since I didnt want to pull the entire harness out, I went ahead and managed to connect most of the 48 wires.
But of course there are doubles, triples and even quadruples of the same color wire, I am left with wires that I dont know where they go.
I checked the FAQ and the only thing related is for the dash wire. meh
What I need is a diagram of each pinout and color of wire to the ecu. Along with the destination of the wire. For example A16 RD/YEL Coolant temp sig
This may be asking alot. Sorry! This site is a valuable resource for a guy like me who has just begun getting into specifics with all these Hondas.
THANKS A LOT!
Old Apr 4, 2008 | 05:09 AM
newby_j's Avatar
Needs More Cowbell
Default Re: Why Do People CUT ECU wires? Now I'm screwed! (gus straussen)
just swap harnesses. it will be better that way in the end.
Old Apr 4, 2008 | 11:13 AM
Default Re: Why Do People CUT ECU wires? Now I'm screwed! (newby_j)
like i said, i have decided to fix the connectors. which means i have cut off the ends. so what good would it be to swap in a harness with cut off connectors?
Old Apr 4, 2008 | 11:14 AM
what- no diagrams?
you hard core guys must have some diagrams.
Old Apr 4, 2008 | 11:23 AM
92egSnatch's Avatar
Default Re: (gus straussen)
try a helms manual maybe
Old Apr 4, 2008 | 09:49 PM
the manuals i have are haynes and chilton. both are worthless. both are have the same wire diagrams. they are 'typical' which means they might work for your car, but at haynes we really dont give a **** if it doesnt.
Old Apr 9, 2008 | 11:35 PM
BUMP!
Old Apr 9, 2008 | 11:36 PM
am I not asking the right question?
do you understand what Im after?
Old Apr 9, 2008 | 11:55 PM
found what i was looking for...
jdmep
Aug 18, 2008 10:02 PM
hybrid1990crx
Nov 21, 2004 09:14 AM
1 Cam Wonder
19
Oct 10, 2004 08:49 AM
EE_Chris
Dec 2, 2003 09:40 AM
BigDaddyRich
10
Aug 21, 2002 09:47 AM
