anyone know if we can fit smaller brake calipers on the r , look inside why
Old Jul 10, 2002 | 10:49 AM
PM-Performance's Avatar
Default anyone know if we can fit smaller brake calipers on the r , look inside why
i want to be able to roll on 13's at the track , but dont want to change the whole hub assembly to the4 lug , can i go with smaller calipers and maybe rotors and find some 13inch wheels in 5 lug to get some nice size slicks on?
or is the only way to swap the whole hub assem?
thanks in advance.
Old Jul 10, 2002 | 11:06 AM
Black R's Avatar
25 Year Member
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (itr206)
.....those darn 2.0 60ft times on slicks eh?
It's gonna be a shitload of trouble for sure.....
Maybe try Brian @ Fastbrakes?
Old Jul 10, 2002 | 11:09 AM
Reid's Avatar
Global Moderator
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (Black R)
Switch to a 4 lug Civic hub assembly for drag racing.
It's not as much work as you think.
Old Jul 10, 2002 | 11:11 AM
migs's Avatar
It might even be more affordable to get some 92-95 Civic Si arms/hubs/etc.
Its really not that hard to swap them all out.
(3) Cotter Pins
(3) 17mm bolts
(1) 32mm drive axle bolt
Plus you have a balljoint puller. Labor for all of this is under an hour.
Old Jul 10, 2002 | 11:29 AM
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (MiGs)
i know its cake , but i dont have the time to keep changing back abd forth i have the parts in the garage to do the hub change, but changing after every race and changing for every race, , . . . to omuch hassle and less race time. . .
yes these 2.0 60 fts are killing me . im gonna try some thing else with these slicks 1st, but im looking for more meat . . . . any bigger slicks that willl clear my fenders?
Old Jul 10, 2002 | 11:32 AM
Reid's Avatar
Global Moderator
For street use you could use the 4 lug front brakes with no problem.
I'd leave them on most of the time if I was a drag racer. Maybe even convert to a GSR brake setup.
Old Jul 10, 2002 | 11:33 AM
vtecvoodoo's Avatar
Future Texas Boy
fastbrakes drag kit
http://www.fastbrakes.com
Old Jul 10, 2002 | 11:34 AM
Rboosted717's Avatar
what 60ft times are you getting? I hit 1.7 60fts with slicks on stock rims. Just up your power and learn how to launch better.
Old Jul 10, 2002 | 11:39 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (vtecvoodoo)
I've seen some totally stripped down Japanese race ITRs swapped from a 98spec 5-lug to a Civic 4-lug for the purpose of reducing unsprung weight (not drag racing). Maybe the Spoon calipers are too expensive? Or maybe the rule doesn't allow non-Honda brakes? I'm not sure.
If the car is light enough that should not be a problem, and of course it depends on the specific driving style too.
Old Jul 10, 2002 | 11:40 AM
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (Rboosted717)
im hitting 2.0's and im looking for 1.7's. . . . trust me when i tell you im burring you with power, Im gonna be pushing anywhere from 280ish to 300 whp in the next week .
right now im doing about 250 whp
and like 180 ish all motor.
with or without the bottle i still get 2.0 60 fts.
i tried going all the way down to 10 psi and still not hooking like i need . someone told me even lower, so im gonna try that and lower the rear, i jacked up the rear to a bit over stock height and lowered the front a bit to try and cut back on body rocking durring shifting . . . . still didnt work .
Old Jul 10, 2002 | 11:54 AM
see if your hitting 2.0 with 250whp then your doing something wrong. I hit 1.7 60fts with 250whp. And my weight is 2650 with driver. My tires were MT 22x8x15 on stock rims.
As for buring me with power with 280-300whp, lets see it. Power isn't everything if you can't hit the times. Heck I was hitting 1.8 60fts with 220whp a year ago. Oh yeah my psi on the slicks are 11psi.
Old Jul 10, 2002 | 11:59 AM
well thats what im saying there is something wrong . . i dont knwo what ive haev tried everything and running out of money and patience.
I slip the clutch , dump the clutch , higher pressure, lower pressure, traction bars, coilovers, motor mounts, slicks, street tires. . . .. i just cant figure it out.
i didnt mean the power thing in that way , i just meant its not a power issue, i know people with alot less than 200 whp and hitting 1.7-1.8 60 fts. . . . i just meant that was deff not the issue.
Old Jul 10, 2002 | 12:03 PM
so whats happening when you launch? Are you spinning the tires, is the clutch just slipping, or is the car bogging off the line?
Old Jul 10, 2002 | 12:10 PM
well before the susp stuf i just blew all this money on . it was wheel hop .. . . now i did the susp stuff , its just spinning off the line . i tried launching anywhere from 7k -about 7500 and its hooking , but spinning a bit too much while doing it . . its not bogging at all right now . it used to though. . i think im gonna try a bit lower launch too , along with lower tire pressure , less burnout, and the rear susp a bit lower.
Old Jul 10, 2002 | 12:21 PM
sgT's Avatar
sgT
I couldnt get better than 1.99 on 22x8x15 slicks.
switched to 22x8x13s and got 1.6-1.7 on average.
Now im probably going to go to a 24.5x8x13
Old Jul 10, 2002 | 12:27 PM
Default Re: anyone know if we can fit smaller brake calipers on the r , look inside why (sgT)
i know a few people who did 1.7 on 8x22x15, incognito is one of them . and im doing the same thing he is . . . there is another dude from ny , with a jdm kit on it and **** , supposedly sponsored by skunk 2 .. . . he owns eastside customs or soemthing ,, , he did 1.7's with em too
Old Jul 10, 2002 | 12:28 PM
sgT's Avatar
sgT
what can i say, i suck
Old Jul 10, 2002 | 12:36 PM
im starting to think i do too , but my times show otherwise. .. so i deff have the top end to more than make up for it . . . but that 60 ft is whats killing me .
Old Jul 10, 2002 | 12:54 PM
ok well fast breaks said i could prob roll with a 10 in rotor and some ls or gsr calipers and that should do the trick , but i would have to drill out the rotor for 5 lug to make em work . . . . i think im gonna do some more research on that and see if this is workable.
Old Jul 10, 2002 | 08:35 PM
t's Avatar
t
Try popping the clutch, I hit 1.8s on Mickeys (stock wheels), launching at 7000.
Triker
Apr 10, 2012 12:57 PM
99Sir99
Apr 5, 2011 08:56 PM
dc4teg95
Mar 19, 2010 10:02 AM
vivid 02
Oct 12, 2006 11:38 PM
JDMorgan
Aug 4, 2005 04:27 AM
