90 civic hatchback with b16a2 swap please help
Old Apr 3, 2008 | 04:54 PM
unikony's Avatar
Default 90 civic hatchback with b16a2 swap please help
Hello all,
I just recently purchased a 90 dx hatch with a b16a2 swap already done to it. I have previously owned two civics, both being d16y8's, so I know a thing or two about civics. It seems as though the swap has been successfully executed, and the previous owner provided receipts for the list of modifications to the car and parts needed to complete the swap. I have read up on some forums and it seems as though they did their homework, not the seller themselves but the brains behind the operation which happened to be the boyfriend. Everything that I have read seems to match the parts that were installed along with it, but I am unsure and skeptical about the wiring. They do have provided a receipt for a Jdm P30 Ecu which appears to be in the car since I actually have what appears to be the old ecu, all scratched up and what not, which was in the trunk. They also have provided the receipt for a wiring sub harness for a 90 civic to b16a2 but the catch is that it too was in the trunk, brand new and packaged, and so I am not sure if this is required or if they have correctly done it another way. I do also find that the intake sensor is there and working, but the sensor connection below that near the injectors is not hooked up since there is no plug for it. There is also another wire that is connected by two plugs that appears to have been cut on one end and I am not sure what this is for and it sits right at the bottom left corner of the engine. Also, at the top right near the power steering there is a fat cable hook up which it too has been cut and is not in use but it is similar to another bigger connection on the other side of the bay next to the other strut so may guess was this is the replacement?. Lastly, right behind the throttle body and manifold coming out of the body of the car is a small hose which has been cut of as well with a circular black housing at the base. I would really appreciate it if somebody could please take a look and examine these wires and let me know what they are/were and if they are needed in order for the b16a2 to function properly. No codes are being thrown so I have no clue if the car is working properly or not. There is actually a test pipe on the car right now and I did not pass inspection for it so I bought a high-flow cat and I am going to have it welded to it. I read up that this car only requires 1 o2 sensor and it is there on the header so I figured that car might be reading this correctly if wired properly but then again I am not sure since I do not know if the pipe is supposed to set off a code. If it is, then since no check engine light is showing t will give me an idea of how well the computer is reading and also let me know that the wiring problems, if any, are not being read.
Thank you,
Konrad
Tomsidle
K Series
Mar 8, 2019 11:46 AM
fidencio74
Jun 18, 2008 09:06 AM
david1magana
May 16, 2005 06:52 PM
