what oil??
Old Apr 3, 2008 | 04:42 PM
ThatGreenGsr's Avatar
Default what oil??
i have a 97 gsr with 118K all stock now what weight oil should i be using i believe the owner before me was using 20w50 and thats what ive been using for oil changes. should i be using something specific? ive been thinkin about switching to full synthetic too is there a specific to use with synthetics? searched for answers but i need a straight answer on what to use?
Old Apr 3, 2008 | 04:52 PM
steveo135's Avatar
Default Re: what oil?? (ThatGreenGsr)
Honda suggests 2 oils for the GS-R:
10W-30 (less temperature range)
5W-30 (superior temperature range)
5W-30 is what Honda strongly suggests and is what I use in my 97 GS-R
as far as synthetics go you should be using the same type of oil (5/10W-30)
Old Apr 3, 2008 | 04:56 PM
deftonerider's Avatar
if you took your car to acura for an oil change they would put 10w30
Old Apr 3, 2008 | 05:40 PM
wegotmorrison's Avatar
Go with Full Synthetic 5w 30 Royal Purple! thats what my Geezer sips!
Old Apr 3, 2008 | 06:23 PM
TOO MUCH TORQUE's Avatar
20w-50 is MAJOR OVERKILL!! what in the world was the previous owner thinking
if you switching to 5w-30 you might start burning oil. If your burning now, you definitely will with 5w30
Old Apr 4, 2008 | 09:07 AM
JdmTypeRdc2's Avatar
5W-30 Mobil 1...you cant get better than that.
You might also want to try the high mileage oil my Mobil 1, since you have over 75k on your car.
hope that helps
Old Apr 5, 2008 | 06:40 AM
jhammond_82's Avatar
Reject Papi
Default Re: (JdmTypeRdc2)
i always have and always will use havoline oil. i use 10w30, and a k&n oil filter. thats just me though.
Old Apr 5, 2008 | 07:41 AM
Blahblah718293's Avatar
Default Re: (jhammond_82)
i started using 10w30 castrol synthetic blend, honda oem filter.
svhiker
Aug 4, 2017 03:19 PM
nudo wo0do
Nov 9, 2004 10:02 PM
luvinmyGSR
Jan 2, 2004 11:31 PM
B18cteg
Sep 8, 2003 10:10 PM
Mike D
Jun 23, 2001 07:26 PM
