Brake Lights Stay On
Old Apr 3, 2008 | 02:49 PM
khmr270's Avatar
Default Brake Lights Stay On
I have a 1990 Honda Accord. My brake lights will not go off unless I remove the fuse from the fuse box. Anybody have any suggestions as to what could possibly be the problem? Does this sound like something major or is a fairly easy fix? Please help and thank you for any suggestions.
Old Apr 3, 2008 | 04:41 PM
TheMuffinMan's Avatar
He knows where you live!
Brake light switch?
Check the pedal if you follow it's arm you should see a small push button switch thing.
It might be jammed.
Old Apr 4, 2008 | 07:00 PM
hondadude's Avatar
Default Re: (TheMuffinMan)
to add to ^ the switch is adjustable.
Some years of Honda have a rubber plug to act as a bumper where the switch plunger meets the pedal arm; if it falls out the plunger goes thru the hole in the pedal arm.
Old Apr 4, 2008 | 07:31 PM
ap716's Avatar
There is a small plastic button looking thing that goes right behind the brake pedal. It might still be somewhere on you floor in the car (mine was) just pop it back in and it will work. if not the honda part number is 46505-SA5-000
propwdialogue
Mar 9, 2012 07:27 PM
Rykertest
May 4, 2009 10:27 AM
PREACHERBREW
May 20, 2008 02:09 PM
Felt.2
Dec 24, 2006 07:49 AM
88crxhfb16
11
Jul 28, 2005 08:07 PM
