b16a2 engine question
Old Apr 3, 2008 | 01:44 PM
kato_si's Avatar
Default b16a2 engine question
well bascially need some help on this. the 2 studs are broken the heads of it are.. could this cause some performance issue and burning of oil? sometimes i see oil that has been spit out from those 2 broken studs but just the heads are. i bought the car like this so could this cause me loosing oil and burning it to? where can i go to get replacements of the studs or what do you all recomend?
Old Apr 3, 2008 | 03:07 PM
cbathgate's Avatar
Default Re: b16a2 engine question (kato_si)
I am not sure about the performance aspect of this problem. This is a very easy fix though, get an easy-out from sears if you don't have one. You can find replacement studs at your local Honda dealership. I also recommend replacing the valve cover grommets with it. I had the same problem on my B16A3 a few years ago.
ej_type_R
Dec 13, 2008 08:39 PM
..::91TEG-G2::..
Mar 13, 2006 03:02 PM
Duke-VTI
May 19, 2005 07:54 PM
YumYumRoLL
Feb 14, 2003 10:54 AM
ckkl
Mar 25, 2002 04:43 PM
