clutch line fluid empty? wtf
Old Apr 3, 2008 | 01:43 PM
dannycraq's Avatar
Default clutch line fluid empty? wtf
well i went to start my car up and pull it in my garage to change my oil pan gasket cause that **** is done, so i was backing up my car and at first it was rough to get it into gear, then when i backed it up into my driveway and turned it off, the clutch pedal went to the floor and stayed ther and i couldnt get my car outta reverse, so i check the fluid in my master, and it was bone dry and i just bled my clutch last week. theres no leaks cause its a new slave cylinder and i have a braided clutch line, what the [freak] could have happened? i gotta bleed it again obviously. when bleeding the clutch should i have the resevoir cap off or on? anybody got any ideas?
Old Apr 3, 2008 | 02:49 PM
philosofy1's Avatar
Default Re: clutch line fluid empty? wtf (dannycraq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannycraq &raquo;</TD></TR><TR><TD CLASS="quote">well i went to start my car up and pull it in my garage to change my oil pan gasket cause that **** is done, so i was backing up my car and at first it was rough to get it into gear, then when i backed it up into my driveway and turned it off, the clutch pedal went to the floor and stayed ther and i couldnt get my car outta reverse, so i check the fluid in my master, and it was bone dry and i just bled my clutch last week. theres no leaks cause its a new slave cylinder and i have a braided clutch line, what the [freak] could have happened? i gotta bleed it again obviously. when bleeding the clutch should i have the resevoir cap off or on? anybody got any ideas? </TD></TR></TABLE>
yeah, if there are no leaks, sounds like you didn't get all the air out.
i bleed the clutch system the same way i would bleed brakes. yes keep the cap on and keep filling it when needed. do not let it run out.
Old Apr 3, 2008 | 04:55 PM
cherroneballs's Avatar
I always leave the cap off cuz in like three pumps you've already drained that little resorvoir on an empty line.
Juans_MX3
Nov 11, 2011 04:51 PM
triple
Nov 16, 2010 11:08 AM
jdmstyleg
11
Sep 27, 2009 06:16 PM
cleanej2
18
Feb 1, 2008 11:42 AM
us31wking
Jun 30, 2007 02:30 PM
