91 CrX Si D15B Swap OBD0 to OBD1
Old Apr 3, 2008 | 01:34 PM
Rexwhippin33's Avatar
Default 91 CrX Si D15B Swap OBD0 to OBD1
Ok I bought a 91 Crx Si it had no motor or tranny with it ,But it was also missing the Engine wire harness, I bought it so i could swap the D15B i had in my Junk Si hatchback that was already converted to ohe body has a obd1 but it was converted sloppy, an the body has a bunch of rust holes But anyways... I Swapped the Motor an the cable tranny along with the engine harness into the Crx an I bought a obd0 to obd1 conversion hatrness followed the instructions an got it all hooked up an the cars running, But my problem is i dont have my heat temp sensors hooked up an i need help figuring out how i can run thed wires, again the wiring was pretty sloppy in the hatch back an the heat sensor wires were ran thru the firewall directly to the ecu but sloppy thedy used a bunch of different color wires an changed them goin from the sensor at the thermostat to the ecu Also it sounds like it might be runnin alil off, it had gas in it when i got it an it had been sittin for awhile, I dunno if that could be why its runnin weird but it could also sound that way cuz i don t have the exhaust hooked up yet jus runnin headers right now, But it does hesitate at about 3 to 4 thousand rpms it sounds like it might be misfiring Will most deff appreciate all an any help
Modified by Rexwhippin33 at 2:45 PM 4/3/2008
Old Apr 3, 2008 | 02:50 PM
Default Re: 91 CrX Si D15B Swap OBD0 to OBD1 (Rexwhippin33)
Please help me!!! currently borrowing boss's car an really wanna start driving my Rex
Genre
Jul 11, 2017 07:47 AM
97civic000
Mar 28, 2011 07:43 AM
danny-mcar
May 1, 2007 03:49 PM
fracas
Nov 25, 2005 06:13 AM
BoRiCuA
Aug 25, 2004 04:57 PM
