**BEWARE** Dash removal
Old Apr 3, 2008 | 10:43 AM
DrGrEeNtHuMb's Avatar
Default **BEWARE** Dash removal
So I was taking out my dash in my dc yesterday, and it got stuck around the steering wheel area. So I proceeded to fiddle with the dash and try different positions to try and sneak it out and around the steering column. Little to my knowledge, while I was tweakin it, the da.mn dash cracked my windsheild. So I just wanted everyone to know, try to actually remove the steering wheel before you go and try to remove the dash. It will save you time, money, sweat and a headache, not to mention a fu.cked up window. EnjoI
Modified by DrGrEeNtHuMb at 1:41 PM 4/3/2008
Old Apr 3, 2008 | 11:33 AM
BlueIntegraBoy's Avatar
Default Re: **BEWARE** Dash removal (DrGrEeNtHuMb)
You could have just dropped the steering column.
Old Apr 3, 2008 | 11:42 AM
yc_dc4mar's Avatar
Default Re: **BEWARE** Dash removal (BlueIntegraBoy)
Old Apr 3, 2008 | 12:09 PM
A's 94 GSR's Avatar
BG-33P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrGrEeNtHuMb &raquo;</TD></TR><TR><TD CLASS="quote">Little to my knowledge, while I was tweakin it, the da.mn window cracked my windsheild.</TD></TR></TABLE>
What?
Old Apr 3, 2008 | 12:40 PM
I did, still wasn't enough room
Old Apr 3, 2008 | 12:41 PM
Default Re: **BEWARE** Dash removal (A's 94 GSR)
Thanks, fixed
Old Apr 3, 2008 | 06:27 PM
96 GSR-T's Avatar
Why did your dash crack your windshield? I seem to be confused here.
Old Apr 3, 2008 | 06:34 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (96 GSR-T)
That actually happend to my friend before. If you remove your steering wheel, it's 1000 times easier.
Old Apr 3, 2008 | 08:04 PM
skata89's Avatar
Mine came out without a problem.....
Old Apr 3, 2008 | 08:27 PM
Avenged7x's Avatar
Default Re: (skata89)
its actually pretty common if u do a search around here on dash removals. Some learn the hard way
Old Apr 3, 2008 | 09:13 PM
Numba1 K Series's Avatar
Hi!
LOL.
I appreciate this educational thread.
Old Apr 3, 2008 | 09:43 PM
Naruto's Avatar
Default Re: (CARMA_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 &raquo;</TD></TR><TR><TD CLASS="quote">That actually happend to my friend before. If you remove your steering wheel, it's 1000 times easier. </TD></TR></TABLE>
That's exactly what I did
Old Apr 4, 2008 | 08:20 AM
Yeah, it was the corner of the dash, above the air vent. It's really firm cause of how the foam in the dash is. Luckily, I work at my families body shop and the window is cheap, around 100 bones and install is free lol.
Old Apr 5, 2008 | 09:21 AM
HybridHatchC1's Avatar
Default Re: (DrGrEeNtHuMb)
well now that you have learned to remove the steering wheel first... just some advice for putting it back in... It can happen just as easy be gentel with it. But i guess since its crack just finish what your doing then get the window fixed
Old Apr 5, 2008 | 10:23 AM
HONDRETTI's Avatar
Default Re: (Naruto)
now i know why the windshield on my old DA was cracked when i went to recover it stripped, couldnt figure that out.
Old Apr 5, 2008 | 10:59 AM
96 GSR-T's Avatar
well hot damn, I will make sure I remember this..... even though a nice fresh windshield sound like something I wouldnt mind buying.
Old Apr 5, 2008 | 02:19 PM
rebo0t's Avatar
always remove steerin
Old Apr 5, 2008 | 03:11 PM
TrustAutoPerformance's Avatar
I've removed a lot of Integra DC dashes before without a problem by just dropping the steering column. Never even came close to having this sort of problem
Old Apr 5, 2008 | 04:39 PM
95_B18b1_Teg's Avatar
drop or ake off columb, got it
im planning on taking mine off here real soon thanks man
89crxhf
12
Oct 7, 2012 09:18 PM
preludepower
Oct 12, 2005 10:50 PM
Honda97
Mar 3, 2005 11:47 PM
DXDOHCVTEC
Jul 20, 2004 09:09 PM
projectcrx
Apr 26, 2002 04:25 AM
