f23 questions!!!???
Old Apr 3, 2008 | 10:24 AM
pluto303's Avatar
Default f23 questions!!!???
can anybody tell me if the f-series bolt ons will fit each other like the intake manifold off of a f22 would fit a f23? i cant find **** about this engine
Old Apr 3, 2008 | 10:38 AM
michaelprice83's Avatar
Default Re: f23 questions!!!??? (pluto303)
Hey bud I had an F23 and I know what its like finding info...... A lot of f22 and H23 parts will fit but I'm not sure all which ones. Do you need a manifold because I have a port matched manifold and tb combo for sale.
Old Apr 3, 2008 | 10:47 AM
TouringAccord's Avatar
H-T Order of Merit
you have to be much more specific. Which F22? It makes a difference.
Old Apr 3, 2008 | 07:33 PM
AK_CRX's Avatar
f22a i/m will not fit an f23. The f22a ports are wider, more oval. air would be slamming into a wall at the cylinder head port. It would physically bolt up if you ground the corner off where your vtec solenoid is, but not a good idea
Old Apr 5, 2008 | 08:41 PM
pluto303's Avatar
Default Re: f23 questions!!!??? (AK_CRX)
o well im just tryin to get some uprgades im parting together a turbo but i want to know some interchangeable parts because i cant find **** for the f23 n theres no write ups on here at all. and im still stuck on turbo or tryin to slap on the h22 head. im not sure if i would really get gains out of the head.....
Old Apr 7, 2008 | 08:03 PM
AK_CRX's Avatar
Or you could swap an f22a head on there, thats what I just did to my f23. It's a bolt on affair and you get a better flowing head, with no vtec (more cam options), and the bonus is the f22a head will accept a stock or aftermarket DSM turbo manifold if the holes are re-drilled.
Old Apr 8, 2008 | 09:57 AM
AFAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pluto303 &raquo;</TD></TR><TR><TD CLASS="quote">o well im just tryin to get some uprgades im parting together a turbo but i want to know some interchangeable parts because i cant find **** for the f23 n theres no write ups on here at all. and im still stuck on turbo or tryin to slap on the h22 head. im not sure if i would really get gains out of the head.....</TD></TR></TABLE>
IIRC, OE F23 intake manifold is best for boost applications due to the larger volume of the plenum and runners.
By the sounds of it, someone needs to do much more reasearch before swapping heads or boosting anything.
slo2k
Jun 9, 2011 09:02 PM
umucho
Oct 20, 2009 05:00 AM
sean92ludesi
Aug 31, 2007 05:16 AM
fknslmd
Nov 1, 2003 12:06 PM
LshatchTurbo
Nov 13, 2002 12:46 PM
