yet another sohc build thread!
Old Apr 3, 2008 | 07:28 AM
00slowcivic's Avatar
Default yet another sohc build thread!
i have been working on this thing for a while but decided maybe i should start a build thread. i just picked up this 93 si hatch. the goals for this car are 11 sec pass and 400 whp dyno.
mod list:
D16z6 block
d16y8 head
crower stage 2 turbo cam
motorla 2.5 bar map sensor
eagle rods
vitara pistons
arp head studs
greddy ebcII boost controller
Neptune tuning (will be done by josh hagen. IntegraLS-T)
walbro 255 fuel pump
860 cc injectors
aem fuel rail
skunk 2 intake manifold
57 trim t3/t4 turbo
3" open down pipe
zeitronix wideband
snail d series turbo mani
ebay short shifter
act xtreme preassure plate
act xtreme unsprung 6 puk clutch
act 7 lb flywheel
68 mm tb
ngk plug wires
huge *** fmic
2.5 in ic piping
probably more just cant think of it off the top of my head
Mods soon to come:
crower springs and retainers
obs lsd
22x7.5 slicks
looks:
motegi 15 in rims
duckbill
front and rear lip
Lowerd on coil overs
this is what the car looked like when i got it. its pretty rough.
Old Apr 3, 2008 | 07:32 AM
Default Re: yet another sohc build thread! (00slowcivic)
after getting the car i pulled the motor to clean it up, clean the bay up a bit . i had tp to a powerstearing delete and remove cruise control. i did a minor wire tuck.. just the headlight harneses. here are some pics of the progress.
got the bay all taken apart and nearly everything removed. long process of cleaning sanding and prepping. also sanded and primed the fenders door and bumpers
then after a **** load of sanding and prepping the car here is primer
Modified by 00slowcivic at 8:39 AM 4/3/2008
Old Apr 3, 2008 | 07:34 AM
before any bashing is put out there about not taking out the brake booster and such this painjob for just the bay was to make it look better. i didint want it perfect for the bay but the rest of the car will be perfect. this is why i went with a single stage paint for the bay. now that is primed there is more sanding and prepping then a fresh coat of paint!
this is the first coat and you will either love or hate the color. its a light brighter in the pics than in in person.
Old Apr 3, 2008 | 07:52 AM
1992Si's Avatar
I can't view photo's here, I hope you have a roll cage in that thing if you want mid to low 11's.
rota92 ran 11.95 with 280whp.
Old Apr 3, 2008 | 07:54 AM
here is a pic of some go fast parts and other goodies for the hatch,
here are some pics of my vitara/eagle block. Turbo2cam put this together and i picked it up from him.
here is the turbo, w/g, mani cam and others
Old Apr 3, 2008 | 07:56 AM
DaveF's Avatar
Default Re: (rota92)
Old Apr 3, 2008 | 08:02 AM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">260 whp </TD></TR></TABLE>
Wasn't that back in 2005 when you were younger.
Like 16
Old Apr 3, 2008 | 08:04 AM
lol i love cookies thanks!. and ryan im not sure i have seen the mazworx car so i dont know the color. its differnet for around here and i like it. and for 1992si i will have a cage put it later in the season. after i get the boot anyway.
Old Apr 3, 2008 | 08:14 AM
AcuraIntegraLS-T's Avatar
Lookin good, this thing needs a tune, get on it.
Old Apr 3, 2008 | 08:22 AM
Default Re: yet another sohc build thread! (AcuraIntegraLS-T)
i will be getting money soon josh so here comes the gt30 and a NepTune!
and ryan i plan on doing the cage the same color. i have the interior stripped and i will be sanding and painting the inside the same color as well.
Old Apr 3, 2008 | 08:41 AM
dmotoguy's Avatar
looks prtty good!
Old Apr 3, 2008 | 08:45 AM
dvsidboy's Avatar
Looks great. Cant wait to see the final of this project. I really like that color. Good Choice.
Old Apr 3, 2008 | 08:47 AM
Default Re: yet another sohc build thread! (dmotoguy)
^^ thanks man. ill get pics of tonight or tomorrow of how it sits now. and woldy when you coming to eastern id to snap some pics!
Old Apr 3, 2008 | 08:55 AM
dvsidboy's Avatar
I will be planning a trip some time Early Summer to hit up EI and do some. Hopefully.
Old Apr 3, 2008 | 08:59 AM
Default Re: (dvsidboy)
damn that means i need to get the rest of the car painted asap!
Old Apr 3, 2008 | 11:09 AM
1992Si's Avatar
Default Re: (00slowcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00slowcivic &raquo;</TD></TR><TR><TD CLASS="quote">lol i love cookies thanks!. and ryan im not sure i have seen the mazworx car so i dont know the color. its differnet for around here and i like it. and for 1992si i will have a cage put it later in the season. after i get the boot anyway. </TD></TR></TABLE>
Here: this color, https://honda-tech.com/zerothread/2262951
Old Apr 3, 2008 | 11:50 AM
Default Re: (1992Si)
thanks! that isnt quite the color its a bit darker
Old Apr 3, 2008 | 02:39 PM
BrightIdeasInc's Avatar
Did he sand the rough spots out on the pistons before installation. Just wondering because they look a little rough. GL with the build tho.
Old Apr 3, 2008 | 06:18 PM
an update of where my is sitting now. still a lot of work left.
Old Apr 3, 2008 | 06:50 PM
who is doing your cage????????? I need the hookup on getting mine welded in
Old Apr 3, 2008 | 07:25 PM
fast2camciv's Avatar
Default Re: (BrightIdeasInc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrightIdeasInc &raquo;</TD></TR><TR><TD CLASS="quote">Did he sand the rough spots out on the pistons before installation. Just wondering because they look a little rough. GL with the build tho. </TD></TR></TABLE>
the pistons are fine, thats the way they are...they are cast not forged. i am the one that built the block.
Looks real good Trevor! i caint wait to see it all finished up!!
Old Apr 4, 2008 | 06:19 AM
Default Re: (fast2camciv)
thanks man! i cant wait to see it go down the track to see what it will do!.
and josh im not sure yet. that is in the works after i buy the turbo and pay for tuning!
Old Apr 5, 2008 | 09:23 AM
Ask Jason about the tune we just put in the hatch, he is in love.
Old Apr 5, 2008 | 10:01 AM
Default Re: (AcuraIntegraLS-T)
soon josh soon!
Old Apr 8, 2008 | 11:36 AM
Did you get the paint done???? lets see some pics
