rear wheel studs
How hard is it to change the rear studs on my 95 civic? i snapped a lug and i wanna replace it before something bad happens. also, i have drum brakes. so id assume its pretty easy?
also. my spedo is off by 40 mph's when i di the at to mt swap. do i just take out the cluster and reset the needle?
theres a walk through in the faq.
they slide in and out, just hit the one thats snapped to loosen it, slide it out of the hole in the hub, slide in the new one, lube it up and use a lug nut to pull it through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannycraq »</TD></TR><TR><TD CLASS="quote">thanks, i tried to look at the faq, but the pic links are broken. </TD></TR></TABLE>
You know, a lot of them are like that. Pics links dead, stuff from 2002-2005, etc. Good information, but the threads are just so old that a lot of those posters and images are gone.
maybe it's time to either find newer threads with pics or dump some of that stuff.
Just a thought.
Just a thought.
