quick question serched but cant find
Old Apr 2, 2008 | 11:05 PM
iluvmyef9's Avatar
Default quick question serched but cant find
i converted my car to a b16 hydro tranny and the rear mount bracket for a cable tranny takes all 17mm bolts and the hydro tranny takes a 17mm and 2 19mm now my question is what rear mount bracket do i use i bought the hasport rear mount and its the same thing all 17 mm any help would be appricateded sprry no tech check my build thread out
https://honda-tech.com/zerothread/1957305
Old Apr 3, 2008 | 09:33 AM
iluvmyef9's Avatar
Default Re: quick question serched but cant find (iluvmyef9)
bump anybody know
Old Apr 3, 2008 | 12:32 PM
jlicrx's Avatar
this is what Hasport says:
"If your 1st generation B16A, B17A and B18A engine did not come with a rear bracket, or you have a B18C, B18B and B20B/Z engine, you will need to purchase one from Acura part no. 50827-SK7-020. It is the rear engine bracket for a 90-93 Acura Integra. <U>NOTE: The two holes on the rear bracket for the two lower bolts at the transmission will need to be enlarged to accept the 14mm x 1.25 bolts that go with that transmission.</U> The bracket is available already modified, from Hasport for $75. Ask for part number EFRBHY."
redDAinteg
Nov 15, 2008 09:54 PM
91slamedrex
10
Sep 20, 2006 03:07 PM
clemsonteg
Jan 22, 2006 06:22 PM
vhd
Nov 9, 2001 05:10 AM
