I Need Help!!!! F22b2-> 92 civic
I Just Recently Crashed my 97 Accord lx and i would like to Swap My F22b2 Into My New 92 civic. Does anyone have anything they can help me with(Swap Guide,Personal Expeirence). I heard that the axel angles will be off is there other axels i could use?? I need my new car on the road soon!!! Thanks
this really isn't an Accord forum question since your question is more about the Civic chassis. But...
There are a couple ways you can go about it...
-Complete Accord swap, motor/transmission/shifter/shifter cables/etc.
-1/2 and 1/2 swap, Accord motor with an adapter kit that will allow the use of either a B series tranny or a D series tranny. That way you don't have to modify the chassis for the shifter and cables.
For more info on the 2nd option, check out the Hybrid forum. Search for things like H2B adapter and F2D adapter. It's been done before so you should find some good info in there.
for f 2 d check out http://www.bisimoto.com. works great in the eg chassis. F 2 B is cool too, a bit more money than first option. f2d requires drivers side motor mount modification (cutting/welding) f 2 b doesn't require any cutting/welding. or you can go full on f swap (done exactly like an h22 swap) lots of info on these.
If you use the F/H2D adapter plate you can keep the axles that you have now. If you find a swap thread that is using the F trans I'm sure it will tell you what axles to use.
