1990 EX lags til engine light pops on...
My wife drives a 1990 Accord EX. It's had this problem for a short while now. Not all the time, but a couple times a day we'll start it up and take off. It lags no matter how far down you press the gas pedal. Then after a while it snaps out of it and the engine light comes on. One thing I figured out is that if you let go of the gas and hit it again real quick it'll snap out of it sooner.
It had a couple other problems that were recently fixed by a Honda/Acura specialist and this was supposed to be one of them. Main relay, distributor cap, distributor o-ring, tube seals for spark plugs, valve cover seal, condensor fan, radiator cap, and speed sensor.
We get it back and it's still doing the lagging/check engine light thing. Any ideas?
Thanx in advance for the help.
do this!
Look for a two pin connector on the right kick panel on the passenger side.
Use a paper clip, or an AMP male connector jumper. [image]
Turn the ignition to ON (II.)
The check engine light and/or D4 will blink a code when the
service check connector is jumped (shorted) with a set of jumper pins.
Emission Diagnostic Trouble Codes (Generic )
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors, (Main Relay) - noted by Techauto
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
23 Knock sensor
58 TDC sensor #2
jdmcrx_echelon
Apr 7, 2008 07:37 PM
trz103
Apr 11, 2006 07:44 PM
