Genuine OEM Honda S2000 AP2 17" JDM Wheels Yokohama AVID W4 Tires
Old Apr 2, 2008 | 07:09 PM
AbsolutGentry's Avatar
Default Genuine OEM Honda S2000 AP2 17" JDM Wheels Yokohama AVID W4 Tires $1189
For Sale @ $1089 O.B.O.
This is a Genuine Set of OEM 2005 Honda S2000 17" wheels with bearly used Yokohama AVID W4 Tires. These wheels are NOT fake or cheap imitations and are not bent or cracked. They came off a S2000 which the owner sold with aftermarket wheels because he had to leave the country. These rims perfect upgrade for someone who has an older S2000 with 16" rims. They will give your S2000 the newer look. These are by far one of the best looking Honda rims, due to the larger offset, the weight is reduced for better handling and braking.
Genuine Honda S2000 Aluminum alloy wheels are manufactured using advanced technologies to maximize quality and performance for motor enthusiasts. Differing from typical wheels, Honda uses an advanced flow-forming process to make the rim section. This process gives the aluminum a semi-forged material structure that adds strength and rigidity to the rim. Because the material is so strong, the rim thickness can be reduced to save weight and maximize ride comfort and while improving performance!
These wheels will fit many ACURA, HONDA, TOYOYA, NISSANS with the same 5x114 bolt pattern.
These wheel come staggered from the factory. (Rear wheels are wider) to give that aggressive look and better RWD grip performance.
These genuine wheels, not fakes retail for $1900! Not including shipping and tires!(http://www.handa-accessories.com/s2000-04.html)
Bolt pattern: 5x114
Two front rims
Size:17 x 7 with 55 offset.
Tire Size: 225/45/17
Two rear rims
17 x 8.5 with 65 offset
Tire Size:245/45/17
Tires:
Ultra High Performance All Season
Yokohama AVID W4s.
Treadwear: 400
Traction: AA
Temperature:A
Speed rating: W (168mph!)
Tread Left: 95%
Retail Price: $500(not including shipping)
These tires were designed for the everyday driver who want COMFORT, LONGEVITY, without sacrificing PERFORMANCE. Quiet and high tread life while having ultra high speed stability. The AVID W4s radial is Yokohama’s Ultra High Performance All-Season tire designed to take everyday driving to a new level of comfort and confidence. The AVID W4s radial was developed to provide sporty cars, coupes and sedans with good treadwear, responsive handling and year-round traction, even in light snow. The tire's structure includes twin, high-tensile steel belts reinforced by nylon to provide responsive handling and high-speed durability.
For Serious Inquires Call:
Grant @ 626-347-3772 (blocked numbers will not be answered)
No low ballers please. Price is FIRM. I accept Cash or Cashier's checks only.
Modified by AbsolutGentry at 2:14 PM 4/5/2008
Modified by AbsolutGentry at 2:15 PM 4/5/2008
goldgreen90ef
Wheels
Jan 31, 2011 05:31 AM
AbsolutGentry
Wheels
Nov 24, 2008 11:35 AM
mytran80
Wheels
Aug 25, 2008 08:35 PM
