JDM fog light and high beam wiring instructions.
Old Jul 10, 2002 | 09:04 AM
Nighthawk GS-R's Avatar
New User
Default JDM fog light and high beam wiring instructions.
ive used the search didnt find what i was looking for. im doing the jdm front end on my car and need to now how wire the highbeams and fogs.
thanks in advance
Old Jul 10, 2002 | 09:12 AM
98R-1144's Avatar
Default Re: JDM fog light and high beam wiring instructions. (Nighthawk GS-R)
high beams you will need to cut off the stock plugs and put female connectors at the end to plug into the jdm harness
as for the fogs, you will need a switch and relay to hook up to the fog light spade in the jdm harness
Old Jul 10, 2002 | 10:44 AM
Fuminsho's Avatar
Default Re: JDM fog light and high beam wiring instructions. (98R-1144)
Didn't someone post a picture of the proper pins to us awhile back?
Old Jul 10, 2002 | 12:00 PM
Mike M's Avatar
Founding Member
Default Re: JDM fog light and high beam wiring instructions. (Fuminsho)
https://honda-tech.com/zerothread?id=105247
and from Merrits page
NOTE: On a NON HID Housing you won't have a white wire, you will just plug the oem 9006 plug into the bulb.
Old Jul 15, 2002 | 10:09 PM
Flamenco-T's Avatar
Default Re: JDM fog light and high beam wiring instructions. (TypeRmsm)
nice illustration..very helpful...
on the high beam, do you just cut the pos wire out of the stock USDM harness and connect it to the Hi-beam on the main harness as illustrated above ?
what about the ground wire on the stock harness? leave it as it is or run it to a ground as well ?
tia
[Modified by Flamenco-NA, 1:09 AM 7/16/2002]
nelson999
Jul 24, 2008 11:52 AM
egblack94
Jul 22, 2007 08:31 AM
itsjeezergsr
Mar 18, 2007 10:11 AM
Bob_760
Dec 16, 2006 12:47 AM
