i need help finding out what this part is...
Old Apr 2, 2008 | 05:45 PM
j_DC2_m's Avatar
Default i need help finding out what this part is...
ok so i dont know what this part is called but im gonna try my best to describe the part. so my car got hit on the DRIVER SIDE REAR panel. ok well when it got it the wheel got bent inward... the part located on the left if your looking at the rear driver side wheel. so basically.. --(X)-O---- x mark the spot.. its the part that is holding the whole wheel basically.. please dont be a @ss and make fun of me becus i dont know what part it is. lol thanks
Old Apr 2, 2008 | 05:49 PM
z6hatchboy's Avatar
Default Re: i need help finding out what this part is... (j_DC2_m)
wheel hub assembly? the same as the knuckle in the front, but for the rear?
Old Apr 2, 2008 | 05:54 PM
Civicman86's Avatar
Anyways you can get some pictures? Or maybe draw a sketch and post it?
If not what is the o on your diagram in the post?
Froth's Avatar
Default Re: i need help finding out what this part is... (z6hatchboy)
Rear trailing arm? Point it out in this pic. Rear trailing arm is 15 in this pic.
-Froth
Old Apr 2, 2008 | 05:59 PM
Civicman86's Avatar
Default Re: i need help finding out what this part is... (Froth)
Yeah if the O on your diagram is the wheel hub, then the trailing arm is to the left of that. Its a pretty large peice.
Old Apr 2, 2008 | 06:06 PM
j_DC2_m's Avatar
Default Re: i need help finding out what this part is... (Civicman86)
YES!! omfg i love you guys ahahha thanks for helping me out. yes its that part number 15 uhh can anyone tell me where to get that piece? thanks again
Old Apr 2, 2008 | 06:09 PM
z6hatchboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote"> trailing arm ...</TD></TR></TABLE>
Thats what that was, it was on the tip of my toungue . You can get that piece from a junk yard.
Old Apr 2, 2008 | 06:17 PM
j_DC2_m's Avatar
when the wheel is bent like that is there anything else wrong with the brakes and the whole assembly? so basically the car is like this | |----------\ \ not that bad but something like that. thanks again
Old Apr 2, 2008 | 06:21 PM
Civicman86's Avatar
Make sure the upper control arm (#8 or 10 depending on your model) and lower control arm (#19) is not bent. The wheel assembly (brakes and what not) should be ok. IF the top of the wheel is bent in towards the car then its likely that the upper control arm is bent.
Old Apr 2, 2008 | 06:29 PM
j_DC2_m's Avatar
Default Re: (Civicman86)
should i just change the whole thing then? its a 92 si hatch
Vtec04
Jan 26, 2017 10:24 AM
Jahz
Paint and Body
16
Jul 20, 2013 09:01 AM
whyS0serious
16
Jun 27, 2010 02:27 PM
robotnik
Dec 4, 2005 04:42 PM
