Car randomly shut off,and now wont start back up.
Everything was fine and i was just cruising down the road. When i came up to a stop sign the car died and would not start back up.
I check my timing and changed the dizzy with new plugs, what else should i look for. Like i said it just shut off and wouldnt start back up,yet it was driving perfect before that.
The oil light did come on prior to it cutting off,but its due to a bad sensor,it did it on my last motor,and this one is freshly rebuilt with new reman oil pump.
Modified by jaredvabeach at 7:03 PM 4/2/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9t4fodo »</TD></TR><TR><TD CLASS="quote">I had the same problem, i had an ignition switch go bad on me.</TD></TR></TABLE>
I've heard of that happening.
1993 honda civic lx.
rebuilt bottom end,y8 head,adj cam gear so the timing is perfect.
CEL for wideband 02,since its a vtec economy ecu.
Ice changed ecu's,dizzys,wires,plugs,tryed starting fluid,and i just soldered on a ignition switch,not the whole assembly just the switch. I still got no where.
I was simply driving and it cut off.
Hatch It
Dec 14, 2004 07:40 PM
