what could it be?
whats up honda-tech! well i got a little problem with my 96 jdm gsr swapped eg. when my car is super cold meaning left overnight, as soon as i start it at around 2.3k the car begins to studder, it only does that if you lightly hold the rpms around there. but as soon as the motor warms or i go "wot" the problem goes away. things i have done: new iac, new coil. spark plugs, cap, rotor and air filter and i also checked all my vacuum lines and its all good. im thinking that maybe its a faulty O2 sensor but i have no check engine light, my check engine light does work incase you are wondering. help!!!!
The ECU runs open loop when the engine is cold, ignoring or waiting for some sensor inputs like the one from the O2 sensor that needs to be hot to work. So forget about that idea.
right before i put the new dizzy. i was obd2 gsr ecu. and it ran good. now i have and obd1 chipped gsr ecu. sorry for the double reply it use to do it bad around 2.3k now its around 900 rpms but way slightly barely noticible
JinDIESEL
Sep 17, 2004 06:33 AM
J MaCk gSR
Aug 26, 2004 09:29 PM
