camber degrees
I daily drive and autocross a dc2 and i'm curious if my camber is too negative. My mods are PIC coilovers 12f/14r, 22mm rear sway, stock front sway, and 205/50/15 Azenis 615's. My camber is set to -2.5front and -2 rear. What would you guys set the camber too since i still dd my car? Also, should i adjust the toe?
i run 13k front 12k rear advance design coilovers with a 19mm rear bar and 195 re01r. all in a supercharger SM class DC that i daily.
zero toe on all 4 corners, -2.75 front and -2.2 rear
new setup and i havent autoXed it yet so i cant say how it works out there, but on the street its just fine as far as tire wear goes
Ive been running 2.5 front and 1.75 rear in my dc2. I primarily autox it and occasionally drive it in the summer. As long as your toe is reasonable and you rotate your tires regularly you should be ok. You dont need alot of rear camber, you could go with 1.5 in the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron M »</TD></TR><TR><TD CLASS="quote">what would you recommend for toe since i drive my car all the time?</TD></TR></TABLE>
I just have the alignment tech set the toe as close to zero as possible.
