Look at this. will be out sometime this year.
Old Apr 2, 2008 | 09:50 AM
SFWD tC's Avatar
Default Look at this. will be out sometime this year.
Old Apr 2, 2008 | 09:55 AM
BoostedJeff's Avatar
Default Re: Look at this. will be out sometime this year. (SFWD tC)
Any more details? lol
Old Apr 2, 2008 | 10:00 AM
SFWD tC's Avatar
Default Re: Look at this. will be out sometime this year. (rota92)
its going to be AWD.
Old Apr 2, 2008 | 10:06 AM
SFWD tC's Avatar
regular
MR.POWERSHIFT's Avatar
thanks
Old Apr 2, 2008 | 10:07 AM
tony1's Avatar
Factory RSX front suspension?
Old Apr 2, 2008 | 10:28 AM
SFWD tC's Avatar
Old Apr 2, 2008 | 10:32 AM
tony1's Avatar
Looks like the motor got squished, must be a suby. lol
Old Apr 2, 2008 | 10:35 AM
DaveF's Avatar
omg i gotta post in every threaD !
Old Apr 2, 2008 | 10:52 AM
AR Fab's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Haha That thing is going to be cool! What class will it be ran in?
Hope it shows up more than the ESX one</TD></TR></TABLE>
Modified class/AWD9.5" tire class in australia.....
Old Apr 2, 2008 | 11:57 AM
SICKM's Avatar
Nice to see someone using their brain and keeping with the factory geometry and independent rear end. (There is no need to go crazy, if a 3300-pound car goes 9.0 and 1.3 60ft then take 1300 pounds out and keep it the same )
It looks like you have the factory 6 speed in there. The PPG gear set works great and this is even better: http://www.kaps.cz/zavodni.php...g=eng
I hope you have no plans of running the Junk Auto’s, cost too much to run and have **** ratios.
Is this going to be a steel body? That would be really cool.
Good luck with it looks like a fun project that WILL work.
Old Apr 2, 2008 | 12:26 PM
AR Fab's Avatar
Default Re: (SICKM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SICKM &raquo;</TD></TR><TR><TD CLASS="quote">Nice to see someone using their brain and keeping with the factory geometry and independent rear end. (There is no need to go crazy, if a 3300-pound car goes 9.0 and 1.3 60ft then take 1300 pounds out and keep it the same )
Good luck with it looks like a fun project that WILL work. </TD></TR></TABLE>
Yes we are using all steel 08 STi body panels. We already broke the ppg gearset at 3900#. The car will come in at 2000# with driver and run the class limit 80mm turbo. We did however slightly change the factory geometry slightly.
Old Apr 2, 2008 | 01:19 PM
SICKM's Avatar
Default Re: (AR Fab)
At 2200 pounds we had no trouble with the gears (There 6 to 5 speed set) other then a driver that could not shift
Old Apr 2, 2008 | 01:26 PM
AR Fab's Avatar
Default Re: (SICKM)
we broke 3rd gear / input shaft and the rear on a 2nd to 3rd gear shift on the street with my slicks and on the way to my wedding sept 28th.....no nitrous at the time ... 35# on a gt42
I'm sure with half the weight breaking will not an issue
Old Apr 2, 2008 | 01:31 PM
SICKM's Avatar
If your interested I made a new output shaft with powerglide splines and straight cut transfer gears, as well as a modified tail housing to fix that problem. After snaping one in a street car I decided to fix the problem and not to deal with it again. lol
Modified by SICKM at 10:59 PM 4/2/2008
Old Apr 2, 2008 | 01:54 PM
1992Si's Avatar
Default Re: Look at this. will be out sometime this year. (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">omg i gotta post in every threaD ! </TD></TR></TABLE>
Some people have better things to do, lol
post *****.
I hope we get to see videos of thing on the track.
Old Apr 2, 2008 | 03:00 PM
Enzo-Racing's Avatar
Default Re: Look at this. will be out sometime this year. (1992Si)
Looking Good....
I still think the engine is turning 2 extra wheels...
Have some fun with it then now then convert it to RWD....
Old Apr 2, 2008 | 03:38 PM
AR Fab's Avatar
Default Re: Look at this. will be out sometime this year. (Enzo-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo-Racing &raquo;</TD></TR><TR><TD CLASS="quote">Looking Good....
Have some fun with it then now then convert it to RWD.... </TD></TR></TABLE>
Yea yea yea...lol
At any moment we can cut the rear half off and add in the proper tubing for a nice 9" rear...but im not interested in that any time soon....
BTW....Im anxious for you to come down and wire it for me
It been a long time since we took (drag) racing this seriously so I cant wait to get back on the drag strip...We are really not concerned with sancitioning bodies as much as we are concerned about traveling around to each of the tracks on the east for their version of import racing events...but we may show up to a few Nopi/BOTI races just for the pure pleasure of staging against some fast Modified cars...win or lose...We don't care...
Self Funded
No Points
No Money
No Trophies
I just want to go fast!
Howard
Old Apr 5, 2008 | 10:01 PM
d1deez's Avatar
Old May 12, 2008 | 02:31 PM
AR Fab's Avatar
Default Re: Look at this. will be out sometime this year. (d1deez)
Here is a few updated pictures.
Started the header this weekend and found out I needed a few more tight radius bends then I had. Thanks for all the help from SPD on their great in-stock selection of 321 SS! We have used both Burns and SPD collectors for years, both of which are crafted very nicely but SPD prices made my wallet happier this time around.
The chassis is a roller now......its been rolled from one end of the shop to the other lately...pretty much getting in the way of all the other customer projects in the shop....I have the mid plate machined but awaiting the clutch pkg. Engine is finally done! Aluminum rods were never meant to be in a Suby block! NEVER! Had to remove .250" out of the block halves and .XXX"(disclosed amount) off the rod cap....That was an awkard conversation with the rod manufacturer! I bet the boys in Puerto Rico are dealing with this right now! Since they have ordered a few sets so far....
Howard
Old May 12, 2008 | 03:05 PM
DaveF's Avatar
Default Re: Look at this. will be out sometime this year. (AR Fab)
any particular reason for keeping the rear independant suspension ? as opposed to going with a more conventional rear and rear suspension (4 link)
Old May 12, 2008 | 03:21 PM
AR Fab's Avatar
Yes the reason is thats what makes a Subaru a Subaru.
2. weight savings. what we have built is much lighter then any 4link setup we looked into....even the Strange Modular rearends are heavier. The Ford 8.8 is even heavier too.
3. Budget. At the moment I already had the components to build the indepenent rear in the manner we did.
4. We had Frank at the Driveshaft shop make the rear axles and hubs for us...he spent so much time on them...
Howard
Old May 12, 2008 | 03:30 PM
DaveF's Avatar
i just figured most all racecars were configured in one "type" of fashion. double frame rail/ 4 link/ x link/ solid rear axle. but who wants to spend 20 k on a MW rear !
the car looks cool though
will you be running in the US or is the car being built to run in AUS ?
Old May 12, 2008 | 03:43 PM
AR Fab's Avatar
US car...
The Modified Class allows AWD in tube chassis form. Besides that I can race at the local tracks and have alot of fun.
Its my car Dave...
Old May 12, 2008 | 03:46 PM
DaveF's Avatar
man, now i really wanna see it with the body on and ready to go after seeing that !!!
bad *** Howard
