April FS Sticky
Old Apr 2, 2008 | 02:54 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default April FS Sticky
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for Race Car parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and I will delete it.
3) you are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, all your posts in the FS sticky will be deleted
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
We will delete any BS we feel does not belong in here.
Modified by boostedcivicsir at 4:02 AM 4/2/2008
Old Apr 2, 2008 | 05:15 AM
DaveF's Avatar
Default Re: April FS Sticky (boostedcivicsir)
updated as of 4-20-08
* thumbs are clickable !
b18c1 longblock 1500 OBO
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
* pulleys MAKE OFFER
*obd2b to obd2a jumper harness
150.00
*AEM 1020 (obd2a)
- setup for hall sensor (T1 trigger or AEM EPM)
- comes with serial cable and the latest software
900 shipped
* B16 block with crank. block has some messed up holes where driver side mount bolts on, can be fixed. 75.00 + shipping
* Billet Aluminum shock tops from Strange Engineering50 shipped
* Circuit worx 4.7 final drive for b16/ls trans 500 shipped
* Crane Ignition HI-6 with LX-91 External Coil & coil wire 250.00
* Skunk2 Intake Manifold (fits b16/b17/ITR) 150.00
* Str sparkplug cover 75 shipped
* Greddy TVVC Boost Controller 200.00 the most bad *** manual boost controller ever !
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
* ACT Streetlite Flywheel - 150 shipped (clutch in picture is sold !)
* Autometer 3 3/4inch Sport Comp Tach, with mounting bracket 75.00 shipped
_______________________________________________
<U>Innovative mounts for EG chassis</U>
* anodized black, billet aluminum mounts with the grey "race durometer"
Brand NEW
350.00 shipped
__________________________________________________ ___
Oil Catch can
80 shipped
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
__________________________________________________ __________
10 inch tall coil springs
* fits 2.5inch shock
* 350lb rate
50 shipped
1993 honda civic coupe DX
4250.00 OBO OBO OBO !!!!
* 1.8L B18B complete Swap
* Aftermarket head unit and speakers
* tokico 5 way adjustable shocks, with skunk2 coilovers(rear drag launch springs)
* skunk2 front camber kit
* TCI upgraded axles
* Lakewood traction bar
* 15x6.5 Konig Traffik wheels in great shape, NO curbs or scratchs, with annodized black lugnuts
* 205/50/R15 Falken Azenis
* rear disc conversion
* aluminum rear lower control arms
Modified by DaveF at 10:49 PM 4/20/2008
Old Apr 2, 2008 | 06:25 AM
West Werks's Avatar
Default 2.2l B-Series
2.2 (2224cc) B-Series (85mm X 98mm) Long Block
very low miles (maybe 5 Hours on it)
Includes:
Castillo's 98mm B20a reworked crank
CP Custom 85mm 15:1
Crane / Ferrera Roller Cam System Custom Grind (.520 lift)
AIR Intake with Bosch Blue Top Injectors setup for Methanol
Custom Cunningham Ultra-Light rods
Endyn b16a Head - Flowed 301 CFM at .500 lift on PortFlow's Superflow
Golden Eagle sleeves and .75 deck riser
ARP fasteners through out - Head Studs, Main Studs
Old Apr 2, 2008 | 06:39 AM
WHTZ's Avatar
Default Re: April FS Sticky (2 0 3)
T4/T67 800$... (Your choice of backhousing, .68 or .96!
Old Apr 2, 2008 | 08:05 AM
SP GARAGE's Avatar
Default Re: April FS Sticky (WHTZ)
h22 2.3L stroker kit
h23 OEM crank polished
h23 rods
arp rod bolts (new)
jdm type-S pistons std (new)
oem std rings ( new )
acl bearings (new)
$500
Old Apr 2, 2008 | 08:34 AM
Ineed$'s Avatar
Default Re: April FS Sticky (FLATBUSH PROJECTS)
Turbosmart 45mm Wastegate w/3 different wastegate springs - asking 250
Contact me by pm
Paypal certified
Old Apr 2, 2008 | 10:20 AM
ExospeedAMcrx's Avatar
BRAND NEW Weldon 2047 Fuel Pressure Regulator $265 + shipping
Fully adjustable pressure settings
Teflon diaphragm with o-ring seal ensures leak free operation
-12 pressure and return ports
Capable of flowing well over 10 gpm
.438" bypass orifice
Compatible with all known racing fuels including nitromethane, ethanol, and methanol.
1/8" NPT Gauge Port
1/8" NPT manifold pressure reference port
Old Apr 2, 2008 | 11:48 AM
philipwight's Avatar
Default Re: April FS Sticky (ExospeedAMcrx)
M&W pro 14 cdi box. $750
Motec m400, m600, m800 completed harness for Honda b-series. Raychem dr-25 shrink wrap used. pm me for details if interested
Old Apr 2, 2008 | 12:05 PM
building boost's Avatar
Default Re: April FS Sticky (philipwight)
OneFab t4 top mount manifold w/ tial 46mm wastegate and 4" downpipe vband b-series. $1400
ITS t4/t66 ptrim, .81 4" backhousing, dual ball bearing turbo. used for 2200 miles. mint. $1000
TIAL 44mm wastegate w/ flange. $300
4" steel exhaust w/ magnaflow 4"x5" n1 muffler and vband flange for a delsol. goes over the control arm and does not touch anywhere at all. $500
mFactory 4.78 final drive for gsr. $400
mFactory 4.92 final drive for b16. $400
buddy club prospec 2.5" stainless steel full exhaust system w/ testpipe for a delsol. $300
Tilton twin disk w/ 9lb flywheel oc-11 b-series w/ hydraulic throwout bearing and master cylinder. $1200
apexi pillowball front shock tops. $100
legit mint ctr/b16 transmission, stock differential. $600
Modified by building boost at 7:59 PM 4/3/2008
Modified by building boost at 11:33 AM 4/14/2008
Old Apr 2, 2008 | 12:21 PM
bracket 4 life's Avatar
parting out my hot rod drag integra.
$1100 shipped comes with -10an welded bung on the rear of the valve cover
GSR HEAD
Supertech inconel valevs
Rev custom springs
Crower tit. retainers
Type R cams
BDL cam gears
http://www.weldonracing.com/pr...lator
the unit is hardly been used maybe 2 or 3 passes at the track looking for 150 SHIPPED
Gt40r turbo 4082spec $1050 shipped in great shape
PHX425 gt42 turbo BRAND NEW never used 1100 shipped
weldon 2035a with bdl fuel filter 550 SHIPPED
front mount custom turbo manifold, used on eggum racing civic. 800 SHIPPED
needs 60mm wastegate
tial 44mm wastegate $250 shipped
Venom racing intake mani with 75mm edlebrock tb 500 SHIPPED
B16 tranny with phantom grip hand cuff, quafie (sp) lsd $1200 shipped
Old Apr 2, 2008 | 12:35 PM
h22 civic's Avatar
24.5x8.5x15 m&h slicks plenty of meat 200 bux
zex dry nitrous system mint and complete with bottle 300
k-teller mandrell bent full 3" stainless exhaust for 96- civic fits 100% perfect like oem no hits at all 3" resinator 18" long ,3" flex expansion joint,3" magna flow turbo muffler sound excellent not raspy in perfect condition $375
msd rpm activated switch $50
C/M stage 4 95 h22 disc used good shape bout 700 miles on it make offer
Modified by h22 civic at 6:25 PM 4/6/2008
Modified by h22 civic at 7:46 PM 4/7/2008
Old Apr 2, 2008 | 12:59 PM
Adam F's Avatar
Default Re: April FS Sticky (h22 civic)
I have a few good parts for sale.
Brand new 50mm TWM K20 ITB with fuel rail and tps: $1200
Motec M4 with Honda harness. Also included, switch panel, ignition expander and lambda: $2000
Golden Eagle B-series Cam Gears 1 red and 1 blue new: $75 each
Golden Eagle B-series Cam Gears 1 red and 1 blue used: $50 each
Odyssey PC 625 battery and charger: $100
Please IM if interested
Modified by Adam F at 6:53 PM 4/21/2008
Old Apr 2, 2008 | 03:47 PM
h22chilton's Avatar
* B A N N E D *
Obd1 plug and Play SMC Autronic Standalone.
Will trade for 13x7 rims for slix, skinnies, n/a h22 any thing. Let me know whtchya got
or shipped any where for $1000.00
Software and IAT included
Old Apr 2, 2008 | 08:38 PM
mrbh22's Avatar
Default Re: April FS Sticky (h22chilton)
mods if this is not ok to post i will delete
pm me if you would want something. block is assembled would even prefer selling the whole car for pennies on the dollar. all pics are current title on the car itself is a clear title.
have;
h22 drag turbo manifold.
t3 60-1 with 500 miles
stock h22 head
PRECISION 750 OR 780CC INJECTORS WITH RESISTOR BOX
hand made intercooler piping.
tial 50mm bov
tial 38mm wastegate
3in dp and kteller exhaust
brand new enjo drivers mout and rear mount.
hondata s2oo with boost option
MOTOR
SLEEVED H22 (RS MACHINE)
JE PISTONS 9;1 COATED BY CALICO COATINGS
CROWER BILLET RODS
STOCK CRANK.
ASSEMBLED AND BALANCED.
act light flywheel
act clutch and pressure plate (new disc)
all new seals gaskets bearings from honda!
new timing belt honda.
oil pan tapped for oil return
CHASSIS
full repaint raizin cane by hot hues
full 10 pt by kens kustom chassis
tig welded joints
mig welded plates.
all sound deadning removed.
all interior installed, except sunroof. replaced with a custom piece of lexan.
ex chassis all power mirrors and windows and locks ALL WORK
skunkworks coilovers
perfect si wheels.
would sell it all stupid cheap. all you would need is one good weekend and a tune and you could be on your way to low 10 sec passes. pm me an offer for all of it and you would be suprised what i would take. i have well over 17k in this car. lets see what we can do.
pics in sig. car is unassembled but will sell everything stupid cheap. i just bought a toyota supra so i relly need money! make me an offer and help me out.
Old Apr 3, 2008 | 02:49 AM
Mikey3000's Avatar
I want this stuff out of my garage more than I want money. Make an offer for what you want.
Earls 90 degree swivel hose end
(3) Clampco T-bolt clamps, 3 Inch max dia.
(1) T-bolt clamp, 4.25 inch min dia.
TD05H turbo off of a 90 Eclipse GSX.
Modified by Mikey3000 at 1:42 PM 4/16/2008
Old Apr 3, 2008 | 03:52 PM
TeenyTymer69er's Avatar
Default Re: April FS Sticky (Mikey3000)
I have bnib je turbo pistons b series 81mm with rings.
Part#189681 Asking $450shipped obo. If you want pictures pm me your email.
Old Apr 3, 2008 | 05:17 PM
msmotorsports's Avatar
!!!Garage Sale!!!
If interested in anything please contact me via PM. Thank you!
B18C1 (GSR) shortblock / golden eagle sleeves, JE Pistons 9:1
Eagle connectiong rods, ARP head studs $1,400.00
B18C1 P72 bare head and valvecover. Comes with cam bridges. (No followers, valves, springs or retainers) good condition. $400.00
Ferrea Roller Followers $800.00
Crane cams roller camshafts (Turbo grind) $500.00
AEM plug and play EMS #30-1040. Application chart http://www.jazzproparts.com/Pr...Specs (has been modified for use with T1 cam trigger. Can be returned to stock simply sending to AEM. Great customer service). 50% discount off retail! $800.00
AEM wideband oxygen sensor $245.00
S80 GSR hydraulic transmission, no grinds, 1-5 gears, reverse gear and synchros included. No differential or final drive $500.00
Circuit Worx Final drive 4.72, only 5 passes on it, like new! $600.00
Driveshaft shop Stage 5 axles for 92+ Civics with ABS or 94+ Integras.
Drive Shaft Shop part number AC55. 2006 model
(hubs <U>not</U> included, 1 small tear on pass axle) $550.00
B series intermediate shaft 99 CRV $50.00
Edelbrock 65mm throttle body $220.00
Skunk2 dual valve springs $150.00
Skunk2 titanium retainers $150.00
Golden Eagle -10 fuel rail $85.00
AEM universal fuel pressure regulator $125.00
CBR ignition coils with wire harness (for coil on plug ignition system, distributorless) $75.00
Powermaster 16v battery, like new condition $150.00
Powermaster 16/12v digital battery charger $210.00
GM boost controller solenoid with wire harness $35.00
AEM 5 bolt cam gear $75.00
Moroso rocker switch panel $55.00
Hasport custom machined solid motor mounts. For B-Series into EF chassis. Rear mount and driver side mount only. One of a kind! $150.00
Autometer ultralite oil pressure gauge 2 1/16", Electric (sender included) $40.00
AEM 3.5bar (50psi) MAP sensor with wire harness $100.00
95 GSR thermostat housing with water neck and temperature sensor $50.00
95 GSR intake manifold air temperature sensor $20.00
95 GSR coolant temperature sensor $20.00
95 GSR knock sensor $35.00
B series starter $75.00
Hondata heatshield intake manifold gasket $50.00
Mr Gasket copper exhaust manifold gasket B-series head $30.00
used Cometic head gasket (usable condition) $45.00
Simpson Platinum 5 pt harness (dated March 07) $75.00
Sparco grip pedals, new condition $50.00
Bieffe predator helmet size medium (SA2000 safety rating) - $225.00
shield has been mirror tinted. Few small nicks that have been touched up.
[B]Sparco 5 firesuit, size euro 54, color white/blue trim, SFI 3-2A/5 rated - $445.00
link to Sparco sizing chart http://sparcousa.com/resourceFiles/29.pdf[/B]
Sparco Top 2 race shoes, size euro 43 (US 9.5-10), color black- $125.00
[B]Sparco GP2 race gloves, size euro 9 small, color black/grey- $65.00
Sparco sizing chart link http://sparcousa.com/resourceFiles/17.pdf[/B]
Modified by msmotorsports at 6:25 PM 4/23/2008
Modified by msmotorsports at 7:10 PM 4/30/2008
Old Apr 6, 2008 | 10:45 AM
Alchemist's Avatar
Default Re: April FS Sticky (TeenyTymer69er)
FS:
-H22 Pro2 Cams (BRAND NEW, just opened to take a look) $550 shipped
-H22 Pro1 Cams (BRAND NEW, just opened to take a look) $425 shipped
-Action 1MS Clutch Kit (BRAND NEW) for B series Hydro $340
-Racing Hart Type C2 (Faces can be fefinished (powder coated for $100) and then just need to be polished by hand) 17" 4X100/4X114, I have all center caps not pictured, and local Bay Area pickup Only. Tires are 80% no camber wear. $900
-Marshall Liquid Filled Fuel Press. Gauges (BRAND NEW) $39 shipped.
Old Apr 6, 2008 | 11:44 AM
Desir Performance's Avatar
Default Re: April FS Sticky (msmotorsports)
Gt42r, great conditon less then 300miles make offer.
T3/t67 ho 1500 miles make offer
Nukin Ram horn manny t3 w 3" dp 4 bolt and flex pipe
Bdl 70mm tb w tps make offer
Msd digital 6 with hvc (big blue coil) and new coil wire, make offer
Turbo xs duel stage bc make offer
Kyb agx new in box rear only for ek civic, make offer
Skunk2 coil over (with extra 1k spring for the rear) make offer
Cp pistons 9:1cc, 81.5 mm on Eagle Rods (3/8 bolts)
Vis Carbon fiber hatch with type r wing for dc2 mint
Vis carbon fiber jdm hood for jdm front dc2 mint
Old Apr 7, 2008 | 07:42 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: April FS Sticky (Desir Performance)
1 Gallon fuel cell.
Brand New
Bought from summit racing about a year ago.
Never has had gas put in it.
Its black plastic.
90 Shipped.
If you would like more pics just let me know.
Old Apr 7, 2008 | 04:20 PM
jdmcoop's Avatar
i bought this from tepid1, i am only selling it because i have no time at all to build a car so i'm parting everything out.
its for a dc integra, Custom CSF Radiator. It is made for the 3rd gen Integra's (94-01) and allows the use of a halfcore radiator, but still uses the stock bracket location. It utilizes all factory mounting locations. This was known as the "Gorilla Arm". The radiator has a 1/2" bung welded in the bottom w/ a -6AN fitting for turbo coolant lines.no $300 obo
Old Apr 8, 2008 | 01:08 AM
Drag_S14's Avatar
Default Re: April FS Sticky (jdmcoop)
GT4294, non-BB for sale, brand new. Used for mockup only.
1.15 exhaust housing.
Pics on request.
Looking for $1000 shipped OBO.
blakebonkofsky@geektuned.com
Old Apr 8, 2008 | 03:20 AM
E Town DSM's Avatar
FS Brand New MSD Digital 7 Programable Ignition Box (MSD# 75314)
New Retails for 900
Asking 750 Shipped
Old Apr 8, 2008 | 05:33 AM
SFWD tC's Avatar
Default Re: April FS Sticky (E Town DSM)
selling race car with many extra parts. asking $11,000-obo
you can email me at jlopes@twcny.rr.com or on here for info. will sell motor or car separate.
a href="http://photobucket.com" target="_blank"&gt;&lt;/a&gt;
Old Apr 8, 2008 | 02:31 PM
JDMisGOOD's Avatar
Looking to sell or trade! <FONT SIZE="4"><FONT COLOR="red">Asking $6500 </FONT></FONT>
1993 Honda Civic Race Ready Shell! Drop in your swap and go racing!
Has gone 10.21@142mph
MB Fiberglass front clip
Custom pearl/air brushed paint over $6g's in paint work.
4130 Chromoly tig welded cage
Custom traction bars
Lexan windows
Simpson parachute with custom mount and lever
Custom 4130 Chromoly wheelie bars
Tokico drag suspension
Brembro brakes
SDS Engine management. Crank triggered set up. Includes all sensors and coils.
Moroso switch panel
Moroso fuse panel
Moroso fuel cutoff
Custom wiring and relays
PLX Devices datalogging wideband
Momo Seat
Momo Suede steering wheel
Momo hub
Simpson harness
Full Autometer gauages water,oil,volt,tach,shift light, boost
Rci 3gallon fuel cell
Aeromotive A1000 fuel pump
Aeromotive filter
Aeromotive fuel pressure regulator
Autometer fuel pressure gauge
Earls AN fittings
Earls -8 feed and -6 return lines.
I'm sure there is more...
Great for a weekend racer or update it for Hot Rod. Car is located in Minnesota. Delivery in the lower 48 available!
*Girlfriend not included.*
<FONT SIZE="4"><FONT COLOR="red">Asking $6500 with all of the above listed. </FONT></FONT>
<FONT SIZE="3"><FONT COLOR="black">**No engine,transmission,axles,shifter,turbo setup, radiator,wheels or tires. Will be sold on steelies. Can remove anything to make it cheaper.**
</FONT></FONT>
<FONT SIZE="2"><FONT COLOR="black">Also For Sale, Garrett GT4088R Turbo </FONT></FONT> <FONT SIZE="4"><FONT COLOR="red">Asking $1200 </FONT></FONT>
<FONT SIZE="2"><FONT COLOR="black">Dual Ball Bearing GT40R Turbo assembly. T4 style inlet flange with 3.00" V-BAND exit. Large style compressor housing with 4.00" inlet and 2.50" outlet. Good for 700HP+
Turbine
-Wheel: 77mm w/ 78trim
-Housing: .95 A/R
Compressor
-Wheel: 88mm w/ 52 trim
-Housing: .58 ar
The turbo has 6k on it. Never ran above 16.5psi. Always oil AND water cooled as well as being shut down with a turbo timer.
Made 506whp @ 16.5psi with a 2.0L Honda.</FONT></FONT>
Modified by JDMisGOOD at 5:36 PM 4/8/2008
