HOW TO REPLACE THE FRONT DOOR SPEAKERS?
well i got stuck trying to change my front speakers from my 93 civic, i looks like i need to take the door panel out and somehow it looks like if it doesn't wanna come out.... if there any pointer i will appreciated, before i break something.... thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tru3civicsi »</TD></TR><TR><TD CLASS="quote">well i got stuck trying to change my front speakers from my 93 civic, i looks like i need to take the door panel out and somehow it looks like if it doesn't wanna come out.... if there any pointer i will appreciated, before i break something.... thanks</TD></TR></TABLE>
yes you have to remove the door panel to get to the speakers. make sure you remove all the screw before prying. once the screws are removed, you have to remove the clip that holds the window handle. you can use a small flat head screwdriver or buy the clip remover (at any part store). once that has been removed it's prying time.
when prying, don't go to crazy, pry gentle and every will be fine.
somehow i thought that what was stuck it was the handle that opens the door!!! ok.. damn i was about to yank the panel...
well i thought it would be like that but the new set of speakers i got they are too long but same size in diameter, but the problem is that it hits the base where the stock speaker is seating!!! i dont know if i should cut the section where the stock speaker magnet seats or just take the whole base out but to do so i need to remove the door panel.... any comments welcome... thanks for the help...
lol 6 1/2 is the size for the lower door speakers. If you are replacing the 6 1/2s dont take the door panel off. Its alot of work for no good reason. The speaker cover over the 6 1/2 just prys off, like with a flat head or hell i just used my fingers the other day when i was installing some speakers.
and try to find some speakers with small magnets and not alot sticking out by the actual speaker part because JDM Dude is right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DudE »</TD></TR><TR><TD CLASS="quote">arent some magnets to big to fit?</TD></TR></TABLE>
Well, the factory speakers are flush mounted...you can make trim rings (or if your speakers came with some use them) and mount the speakers to the door panel. I had to do this on my old Escort cuz the mounting depth was too great.
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
*Boostwerks*
Sep 13, 2002 08:52 AM
