B16 head on b17 block?
Old Apr 1, 2008 | 07:32 PM
vtec526's Avatar
Default B16 head on b17 block?
Will a built b16 head with skunk 2 stage 2 cams work with a b17 block? Is the b17s compression too low to run these cams? Sounds like a crazy built but I have had some back luck. Bought a LS vtec swap that had bad blow by. Bore never seeded is my guess, then the mesh filters between the horns from the TSW ITBs were sucked in once again creating more pressure due to possible ring or valve damage. Any info will be helpful. I am willing to sale the LS vtec if you want parts list just let me know.
Old Apr 1, 2008 | 07:43 PM
BlueIntegraBoy's Avatar
Default Re: B16 head on b17 block? (vtec526)
The B17A1's head is the same head as a B16.
widewhite
Apr 14, 2014 08:31 AM
Jhonpebz
Dec 20, 2011 08:55 AM
JspecCivic94
Oct 25, 2005 06:26 AM
JDMLEROY
May 24, 2005 09:45 AM
eg6T
Nov 22, 2004 05:13 AM
