ITR 5 LUG Conversion
Old Apr 1, 2008 | 07:10 PM
MenaceL.A.671's Avatar
Default ITR 5 LUG Conversion
Im doing my JDM ITR with 36mm conversion onto a 2000 integra gsr. i noticed my one side (driver side)of my 5 lug has no abs and the other side has them. What would you guys recommend? should i just drill a hole or just leave it alone?
Modified by MenaceL.A.671 at 4:30 PM 4/2/2008
Old Apr 1, 2008 | 07:35 PM
BlueIntegraBoy's Avatar
Default Re: ITR 5 LUG Conversion (MenaceL.A.671)
Mount the ABS sensor from your GSR knuckle onto the ITR knuckle. Leaving the sensor out will pop up the ABS malfunction light.
Old Apr 1, 2008 | 09:27 PM
Default Re: ITR 5 LUG Conversion (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Mount the ABS sensor from your GSR knuckle onto the ITR knuckle. Leaving the sensor out will pop up the ABS malfunction light.</TD></TR></TABLE>
what if theres no drilled holes? should i drill holes or not?
Old Apr 1, 2008 | 09:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MenaceL.A.671 &raquo;</TD></TR><TR><TD CLASS="quote">
what if theres no drilled holes? should i drill holes or not?</TD></TR></TABLE>
Yeah, you should or else your ABS sensor line will change hang.
Old Apr 1, 2008 | 10:08 PM
EM1adobogirl's Avatar
EricUSC
21
Apr 18, 2009 05:40 PM
MenaceL.A.671
Apr 6, 2008 12:40 AM
TSAngry
Aug 21, 2006 09:26 AM
jdmekrsi
Jul 20, 2004 02:42 PM
mikeweb
Feb 29, 2004 09:23 AM
