si trany prob!
Old Apr 1, 2008 | 06:31 PM
driftam1's Avatar
Default si trany prob!
ok im puting the trany on at the time or trying to the engine is in the car still is there an easy way to put the trany on and line the spindle up with the clutch? its a bitch to line it up any ADVISE PLEASE!
Old Apr 1, 2008 | 06:42 PM
driftam1's Avatar
Default Re: si trany prob! (driftam1)
seriously i want to drive advise !
Old Apr 1, 2008 | 07:07 PM
KazzaF's Avatar
lol.. I wanted to help but i don't' understand what you are saying.
Old Apr 1, 2008 | 07:10 PM
dr_latino999's Avatar
Have a second person to help you; put yourself fully under the transmission if the car is on jack stands / lift and rotate the transmission casing until the input shaft slides in. Once the input shaft starts to slide in, rotate the transmission casing to the proper orientation and then proceed to slide until the dowel pins are in. Then move like the Flash and bolt it up.
Chobits16
Feb 1, 2012 03:09 PM
spens 91 Ef
Jun 18, 2011 11:05 PM
Remiss
May 11, 2009 06:37 AM
Jonathan_ED3
May 14, 2003 05:27 PM
