once aging i need yalls help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tytank7 »</TD></TR><TR><TD CLASS="quote">ok on i know where it is on my car but what dose 6/7 connect to? i im messing the tube</TD></TR></TABLE>
It is a transmission VENT line...it doesn't connect to anything. You are not 'messing' a tube.
It is also very hard to understand what you are trying to say.
yeah i know that now, i got a obo2 scaner and its say its map/baro cirit high input? and sorry its hard to understand im dyslexic i try to reread everything but it never comes out right sorry but thanks for yall help dose any one know anying about this Map/Baro circuit?
From what I can understand of your post, you downshifted by mistake while doing some street racing and now your car does not idle correctly. Right?
If so, most likely you bent some valves.
well map sensor is on the firewall close to the intake manifold. check the connections and check the vacuum lines on the back of the manifold. a vac line probably fell off. find which one, reconnect it. clear the code...... then stop street racing.
hey 117 i read ur post and thanks but im hoping thats not what it is. thats alot of money but what are the signs if a bent valve?
and by the way a new code came up:
P1399
Ignition Contrl Systme or misfire
dose that help any of yall tell me what wrong with my car?
its runing okay but it just wont idea at all like sumtime it will at 300 rpms for like a few mins but thats it.
P1399
v8killaz
14
Mar 12, 2008 07:56 PM
