need ecu pin for a sensor on top of manifold??????
Old Apr 1, 2008 | 06:08 PM
1slowcrx's Avatar
Default need ecu pinout for evap purge solenoid???
look at pix below. located on top of intake manifold. i need the ecu pin for a obd1. it's a 2wire plug for the evap purge solenoid
Modified by 1slowcrx at 7:19 PM 4/1/2008
Old Apr 1, 2008 | 10:01 PM
mtber's Avatar
Default Re: need ecu pinout for evap purge solenoid??? (1slowcrx)
http://www.phearable.net/tech
Old Apr 1, 2008 | 10:55 PM
1slowcrx's Avatar
Default Re: need ecu pinout for evap purge solenoid??? (mtber)
but in the diagram,i dont see an out put for the evap purge solenoid?
Old Apr 2, 2008 | 08:54 AM
Bakeoff's Avatar
You can unplug and remove it without throwing a CEL or effecting driveability... I haven't run one in years. What exactly are you doing?
Old Apr 2, 2008 | 11:48 AM
1slowcrx's Avatar
Default Re: (Bakeoff)
tring to BAr. need pinout to wire it in
Old Apr 2, 2008 | 10:32 PM
mtber's Avatar
Default Re: (1slowcrx)
It is listed if you click: Wiring diagram/colors/pinouts for 92-95 obd1 vehicles
Use that along with a factory helms manual to figure out your issue.
91accord25
Nov 16, 2012 08:28 AM
T3k C
Jul 29, 2006 11:53 AM
enhancedCL9
Aug 23, 2005 07:49 AM
Setsuna F Seiei
Apr 21, 2005 08:39 PM
darrylwfarkas
May 19, 2003 04:34 PM
