idling frenzy!!
Old Apr 1, 2008 | 03:07 PM
socalrex88's Avatar
Default idling frenzy!!
hey honda-techrs! i have a 90 hf stock everything...lately its been idling at 1300-1500 at the rpm. it happens occasionally except for when im warming it up..my ecu threw a code 7 so i knew it was the TPS Sensor...
about a month ago i bought a new TPS sensor and installed it and reset the battery.. it stilled idle funny after that then a week later the problem stopped and the normal idle was at 1200 rpms.
i havent adjusted the idle screw to the manufacture because the idle keeps jumping up and down... so far i had all my belts replaced and a new PCV valve on the intake manifold because i found gas on the intake pipe..
any suggestions is appreciated!!! could it be the map sensor hmm..
Old Apr 1, 2008 | 03:30 PM
socalrex88's Avatar
Default Re: idling frenzy!! (socalrex88)
i checked out the other threads no pictures of how to fix em...all the threads i found about crxs are like four to five yrs ago...someone help!
twocross
29
May 3, 2011 01:03 PM
B17DA-SON
Feb 5, 2010 09:23 PM
5thGeneration
Jan 3, 2008 01:49 PM
chuckd05
Nov 23, 2001 07:53 AM
