FS: Suspension Techniques Sway Bar Set 92-95 Civic 93-97 del Sol
Old Apr 1, 2008 | 02:53 PM
dpetro1's Avatar
Default FS: Suspension Techniques Sway Bar Set 92-95 Civic 93-97 del Sol
Hey guys, just pulled this sway bar set off my old build. only installed for about 4 months.
Suspension Techniques front and rear sway bar set. Part #52161. They are made for 92-95 Civics and 93-97 del Sols WITHOUT oem bars. This set uses bolt on adapters to mount the bars to the front LCAs and rear struts. Both bars are 19mm. They go for $260 new from jegs, all original hardware, bushing and instructions are included. These improved handling dramatically while avoiding switching LCAs, great for the street and track use. Only con is that they rattled on my carsound cat sometimes, nothing major.
$175 shipped. will not separate (the instructions say not too anyways)
scroll down for install pics
Modified by dpetro1 at 7:31 PM 6/6/2008
Modified by dpetro1 at 3:06 PM 9/24/2008
Old Apr 4, 2008 | 05:06 AM
dpetro1's Avatar
Default Re: FS: Suspension Techniques Sway Bar Set 92-95 Civic 93-97 del Sol (dpetro1)
bump
Old Apr 11, 2008 | 02:49 PM
dpetro1's Avatar
bump
Old Apr 14, 2008 | 06:02 AM
MrXclusivE's Avatar
How much for the front shipped to 14226?
thanks
Old Apr 14, 2008 | 06:50 AM
dpetro1's Avatar
Default Re: (MrXclusivE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">
$225 shipped. will not separate (the instructions say not too anyways)
sorry selling as a set only
Old Apr 14, 2008 | 07:00 AM
MrXclusivE's Avatar
Cool. one question if you don't mind, do you still need endlinks for the front bar or the brackets take care of everything?
thanks
Old Apr 14, 2008 | 07:13 AM
Fibercation's Avatar
pics installed?
Old Apr 14, 2008 | 10:52 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrXclusivE &raquo;</TD></TR><TR><TD CLASS="quote">Cool. one question if you don't mind, do you still need endlinks for the front bar or the brackets take care of everything?
thanks</TD></TR></TABLE>
you still use endlinks. there are brackets fr the lca's to attach the bar to the endlinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fibercation &raquo;</TD></TR><TR><TD CLASS="quote">pics installed?</TD></TR></TABLE>
i dont have any of my personal car but im trying to track down a really good write up on installing these bars, i cant find it for the life of me though.
Old Apr 14, 2008 | 11:18 AM
dpetro1's Avatar
Default Re: (dpetro1)
also in the pic. the endlinks are still installed on the front bar. they can be left on and it made it easier to install/remove instead of assembling them under the car. rear endlinks had to come off though so they are in the hardware bag.
Old Apr 16, 2008 | 11:43 AM
dpetro1's Avatar
Default Re: (Fibercation)
found a pic of the front bar. (not my car but exact same bar)
and rear shock adapters
Old Apr 16, 2008 | 08:31 PM
MrXclusivE's Avatar
will this fit 96-00?
Old Apr 16, 2008 | 08:39 PM
dpetro1's Avatar
not positive but id say no. Suspension Techniques lists different part numbers for 92-95 and 96-00
Old Apr 20, 2008 | 03:45 PM
dpetro1's Avatar
ttt
Old Apr 22, 2008 | 05:07 AM
dpetro1's Avatar
where are my CX and VX people, sway bars without changing LCAs
Old Apr 26, 2008 | 09:41 AM
dpetro1's Avatar
ttt
Old Apr 26, 2008 | 09:58 AM
1995Civiccx's Avatar
pm'd
Old Apr 26, 2008 | 10:02 AM
dpetro1's Avatar
Default Re: FS: Suspension Techniques Sway Bar Set 92-95 Civic 93-97 del Sol (1995Civiccx)
replied
Old Apr 28, 2008 | 07:44 AM
ReDemoN's Avatar
DixielandImports Please
It almost looks as if the bolts on the bottom would hit the ground if you had smaller wheels.
What if you have aftermarket rear lower control arms how would these work?
Also do you have to brace the rear subframe?
Old Apr 28, 2008 | 07:55 AM
dpetro1's Avatar
Default Re: (ReDemoN)
bolts are fairly low but i havent had any issues and i have 3 speed bumps in my apartment complex.
aftermarket LCAs arent really a factor, you would still use the shock brackets, thats how the bar is designed.
kit comes with a form of bracing. flat metal brakets that go on each side of the subframe. also these bars are on 19mm and dont put as much stress on the subframe.
Old Apr 29, 2008 | 04:34 AM
dpetro1's Avatar
all PMs replied
Old Apr 30, 2008 | 09:02 PM
dpetro1's Avatar
bump
Old May 5, 2008 | 09:24 PM
dpetro1's Avatar
bump
Old May 9, 2008 | 08:11 AM
dpetro1's Avatar
bump
Old May 11, 2008 | 02:59 PM
dpetro1's Avatar
TTT
Old May 15, 2008 | 01:54 PM
dpetro1's Avatar
bump. trying to get pics back up
