At Wits End
Old Apr 1, 2008 | 01:37 PM
hammergunner's Avatar
Default At Wits End
OK.......i have a Turbo b16a1 that was OBD0
and it had some wired wiring harness on it, that had to square plugs
(1x green resistor box plug and 1x square dizzy plug)
Both plugs had 6 wires.
But my wiring harness on my 91 SI hatchback was
(1x green resistor box plug and 1x ROUND dizzy plug)
the resistor was still 6 wires but the round plug was 8!
after all this messing with it, i tried a 1.6 OBD0 SI motor harness....still no luck
motor would run but would not get past 3,000 rpm.
SOOOO, i upgraded the whole under dash and motor harness to OBD1
(ECU was already OBD1, was using a jumper.)
After all this, got the motor to start but only for a few seconds...after that it died!
the motor has Spark,Gas,and Air, all sensors are wired right, all plugs are wired right........
I Just can't understand whats not working here
Also The timing is right, replaced fuel,oil filter, Spark plugs and wires.
and replaced distributor.
I even check to see if it was the injectors since i went from obd0 to obd1
because of the missing resistor box that obd1 does not have
i put stock obd1 injectors on it, and still nothing.
I'm at wits end with this motor, if i can't get it to run, im junking for scrap metal!
Modified by hammergunner at 3:03 PM 4/1/2008
Old Apr 1, 2008 | 01:38 PM
Default Re: At Wits End (hammergunner)
Since i upgraded the under dash to ODB1, if i can't make this motor work, i'll just swap im my 97 GSR instead
Old Apr 1, 2008 | 02:11 PM
0c00l's Avatar
What ecu do you have? Plus more info:
1. obd0 distro or obd1
2. Did you replace to whole harness?
3. what is managing the turbo
Old Apr 1, 2008 | 02:21 PM
Default Re: (0c00l)
the distributor was OBD1 to OBD0 back to OBD1 again
and just to make sure it wasn't that i took the disturber off my GSR and used that
still no luck
by the turbo, i mean the motor is turbo charged with a garret turbo
and i can't get the ECU code because the sticker pealed off, but its the ECU that was
working with the motor, i bought the motor from another car club member, and it was
working just fine when we pulled the motor out.
And yes i replaced the WHOLE motor harness, and rewired what plugs where not on
the newer harness
Old Apr 2, 2008 | 02:58 AM
Default Re: (hammergunner)
bump
Old Apr 3, 2008 | 08:30 AM
0c00l's Avatar
Open the top of the ECU there should be another sticker or label inside!
Old Apr 9, 2008 | 11:06 AM
still nothing, there is no label inside the ecu
Old Apr 9, 2008 | 11:09 AM
got to motor to start, but the TB pully has to be all the way open to just keep the motor running?
Old Apr 9, 2008 | 03:13 PM
143MYVTECEF's Avatar
you must be throwing a cel. which ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammergunner &raquo;</TD></TR><TR><TD CLASS="quote">got to motor to start, but the TB pully has to be all the way open to just keep the motor running?</TD></TR></TABLE>
did you have to rewire the tps
Old Apr 9, 2008 | 05:49 PM
cel?
what do you mean?
Old Apr 9, 2008 | 05:55 PM
Check Engine Light?
Old Apr 10, 2008 | 03:50 AM
0c00l's Avatar
yep thats it hammer
Old Apr 10, 2008 | 03:10 PM
nothing
Harness was upgraded to ODB1, so the Cluster does not plug in.
cant see the CEL.
but im thinking it was a wiring problem
so im gunna get a new b16 OBD1 engine harness
since the one on there know was a OBD0 to 1 converstion
90civicstdgold
Jul 17, 2011 03:24 PM
b_hoov
Dec 1, 2008 08:17 PM
JokerX-1.6T
Jun 10, 2008 07:10 PM
thegooddoctorceretti
10
Aug 30, 2007 08:36 AM
NikoZai
Mar 16, 2005 05:58 PM
