Classic Hondas All Pre-1988 Hondas.
1967 S800. going to try to fit S2000 engine
Old Apr 1, 2008 | 12:25 PM
Bozwell's Avatar
Default honda
Old Apr 1, 2008 | 12:45 PM
smithenhiven's Avatar
11:11
Default Re: 1967 S800. going to try to fit S2000 engine (Bozwell)
Wow, I don't know what to say. First of all, welcome aboard, glad to see another vintage S-car owner here.
I know it's your car, and your money, and you'll do with it what you please, but in my opinion, it's a shame to see an S800 Coupe, with an original S800 engine (perhaps even numbers matching?), get hacked up to fit a "modern" engine.
If it's speed and "modern"-ism that you're after, why not just buy a modern car?
Old Apr 1, 2008 | 01:30 PM
csingham's Avatar
crazy mad murdock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bozwell &raquo;</TD></TR><TR><TD CLASS="quote">had a modern car.
have a bigger picture of that?
Old Apr 1, 2008 | 02:20 PM
EFinawesomeman's Avatar
Default Re: 1967 S800. going to try to fit S2000 engine (csingham)
Good luck with the setup bro! Can't wait to see this thing get down and dirty..faster.
I'll take that 3rd gen accord front end off you though
Old Apr 2, 2008 | 01:17 AM
Ztlohmak's Avatar
Default Re: 1967 S800. going to try to fit S2000 engine (EFinawesomeman)
This is going to be fantastic! I have been doing up a budget for a s2000 conversion in my S600 Coupe, there is so much to consider! If the plans come off the drawing board and into action, I would love to share and bounce ideas with you.
Old Apr 2, 2008 | 06:23 AM
E-AT_me's Avatar
Default Re: 1967 S800. going to try to fit S2000 engine (Ztlohmak)
i LOVE the way the car looks, though. those AO32R's are pimp!!
Old Apr 2, 2008 | 09:44 AM
NIKE SB'd's Avatar
Wow this should be amazing
Old Apr 2, 2008 | 02:15 PM
cbstd's Avatar
Default Re: (NIKE SB'd)
Welcome, I see you've made the journey over from the UK CRX forum.
I hate to see an old car that could be restored "hacked up," but I will trust that you will do the job nicely.
If it were me, I would graft the S2000 engine and tranny into something that needs the upgrade, like a MGB.
Scott
Old Apr 2, 2008 | 02:22 PM
funkmaster's Avatar
since the car already appears to be a track car, which already has major non OEM body panels I say go for the S2000 swap! If it were an all original gem, id say leave it stock.
Old Apr 2, 2008 | 05:14 PM
Ztlohmak's Avatar
Default Re: (Bozwell)
Indeed, the chain drive rear end makes things difficult. I need to see a later model chassis against mine to find out exactly how different it is. I was thinking going 4 link suspension. What do you think about the location of the steering column? The extractors surely would hit it? I know in Australia I will have to use a collapsible column to pass safetly regulations.
Old Apr 2, 2008 | 09:23 PM
2ndGenGuy's Avatar
Have you seen the one with the turbocharged Fiat motor in it, I think it is... I'm pretty sure that guy swapped in a Ford 9 Inch rear end that he shortened to fit in the car. Judging by the looks of that rear end, it looks possible to do while keeping the chain drive setup in tact...
Old Apr 3, 2008 | 12:25 AM
NW Classic Honda's Avatar
Default Re: 1967 S800. going to try to fit S2000 engine (2ndGenGuy)
Old Apr 3, 2008 | 05:11 AM
ex1z7's Avatar
Oh my.. I love it.. I love every bit of it.. a CARB'D S2K engine? That's sick.. I'll keep it EFI and go ITB's but that's just me..
What a fantastic looking car.. I'm scared to even try looking for one, I can't imagine there are many out there anymore..
Old Apr 3, 2008 | 05:23 AM
MSchu's Avatar
My Name is Nobody
Default Re: (ex1z7)
Might as well tube frame the entire chassis while your at it
Old Apr 3, 2008 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenGuy &raquo;</TD></TR><TR><TD CLASS="quote">Have you seen the one with the turbocharged Fiat motor in it, I think it is... I'm pretty sure that guy swapped in a Ford 9 Inch rear end that he shortened to fit in the car. Judging by the looks of that rear end, it looks possible to do while keeping the chain drive setup in tact...</TD></TR></TABLE>
a ford 9 inch would probably lift the front wheels of the ground for sure! wouldnt mind seeing that! the 8.8 would probably better suited. but the gears are always interchangable. can't wait to see the fabrication work.
Old Apr 3, 2008 | 04:33 PM
cbstd's Avatar
Default Re: (EFinawesomeman)
I could be wrong, but it appears that the S800 does not have the chain drive of the earlier S models, which should make mounting a 8.8" (which is plenty for this application) fairly easy.
I am convinced, a S2000 engine in this beastie is a good idea. Are you planning on building a roll cage to hold this thing together?
Scott
Old Apr 3, 2008 | 06:22 PM
Ztlohmak's Avatar
Wow! Thanks for those pictures! I will have to jack up my car and have a closer look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFinawesomeman &raquo;</TD></TR><TR><TD CLASS="quote">
a ford 9 inch would probably lift the front wheels of the ground for sure! wouldnt mind seeing that! the 8.8 would probably better suited. but the gears are always interchangable. can't wait to see the fabrication work.</TD></TR></TABLE>
Sure does, I got a few pictures of it launching at the drags.
Old Apr 4, 2008 | 09:07 AM
cbstd's Avatar
my dilemma here is whether to graft on the Honda hubs on to the new axle and keep the original wheels (these wheels are very rare) or use Ford hubs and get front hubs made to accept ford wheels giving me the option of many types of wheel and availability of loads of spare wheels
Interesting question. Are the orginal wheels going to give you enough of a foot print with all this new power? If not, I would not feel bad about using the Ford hubs to get a bigger footprint.
Scott
Old Apr 4, 2008 | 10:42 AM
11:11
Would you want to sell those wheels if you went with different hubs all around?
Old Apr 4, 2008 | 04:33 PM
rotten's Avatar
Personally
I'd prefer if you took a basketcase and created a hybrid rather out of that rather than irrevocably modify a pretty nice, restorable car.
Its your car, but are there any unrestorable (to original condition) cars available in your area?
Maybe sell this one and get a cheaper unit in worse shape?
If I were able to liquidate some of my cars I'd make you an offer on the one you have.
-k
Old Apr 5, 2008 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bozwell &raquo;</TD></TR><TR><TD CLASS="quote">the engine swap continues </TD></TR></TABLE>
It better!!
Old Apr 6, 2008 | 05:23 PM
Tomdata's Avatar
Nice project. I think this is a perfect candidate for a megasquirt ecu though. It would be much bette than carbs. Check out this link.
http://www.diyautotune.com/cat....html
Old Apr 7, 2008 | 06:30 AM
11:11
So what are you going to do with the S800 drivetrain?
Old Apr 7, 2008 | 09:58 AM
11:11
If shipping isn't horribly expensive to the US, I'd probably buy it from you.
Old Apr 9, 2008 | 08:16 PM
swifty4u's Avatar
Default Re: 1967 S800. going to try to fit S2000 engine (xyzalvarez)
very interesting. ill be watching this for sure
