A b16b reff question
Old Mar 31, 2008 | 10:15 PM
rotascircuit's Avatar
Default A b16b reff question
hey I am thinkin to buy a 93 civic hatch with a b16b for $3500. I was thinkin to reff the car with that engine so do you think that I can reff that 93 civic with a 98 b16b and its running 0bd1? So it is a JDM engine.................right? any sugg?
Old Apr 7, 2008 | 08:12 PM
mamones-todos's Avatar
Default Re: A b16b reff question (rotascircuit)
NO it wont pass because its Jspec only motors released here (i mean US spec) will pass smog a del sol b16 or 2000 SI
Old Apr 8, 2008 | 10:54 PM
bossman032's Avatar
Default Re: A b16b reff question (mamones-todos)
I passed visual with a b16b motor back in 03!
so it can be done! I don't know the rules now but I did it back then!
Old Apr 8, 2008 | 11:17 PM
EGfosho's Avatar
OG Tech
You can reff any J-spec engine. You just need all the usdm sensors on it. Some on the intake manifold and one for the oil, I think. You need an usdm ecu also.
Old Apr 9, 2008 | 12:41 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamones-todos &raquo;</TD></TR><TR><TD CLASS="quote">NO it wont pass because its Jspec only motors released here (i mean US spec) will pass smog a del sol b16 or 2000 SI </TD></TR></TABLE>
Correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho &raquo;</TD></TR><TR><TD CLASS="quote">You can reff any J-spec engine. You just need all the usdm sensors on it. Some on the intake manifold and one for the oil, I think. You need an usdm ecu also.</TD></TR></TABLE>
Incorrect...There HAS to be a USDM equvilant wich there is not...a JDM b16 has the B16a2 and a3...the JDM b18c-r has the b18c1 and c5. There is no USDM counter part for the b16b it wont pass....not now, trust me i know i went to 5 different places and each one nailed me right off the bat. So i moved no more smog checks w00t
Old Apr 9, 2008 | 01:37 PM
bossman032's Avatar
Default Re: A b16b reff question (B16b-EJ8)
it really depends on the refs, some might let you slide. the important factor is that as long as your motor passes the sniffier test. the refs have control but on a sniffier test they can't do nothing. in my case the ref didn't know or whatever anyways I tired to pass and my car kept failing the sniffier test. so in the end I just said [freak] it..
make the ref on your side and tell him that its a b16a3 equivalent motor and make sure your b16b motor passes the sniffer you should be good!
most of this all depends on how bitchy the refs are. the visual part if they fail you on that and your car passes the sniffer you still fail! so make them your friend and go from there..
good luk!
Old Apr 9, 2008 | 02:08 PM
EGfosho's Avatar
OG Tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Incorrect...There HAS to be a USDM equvilant wich there is not...a JDM b16 has the B16a2 and a3...the JDM b18c-r has the b18c1 and c5. There is no USDM counter part for the b16b it wont pass....not now, trust me i know i went to 5 different places and each one nailed me right off the bat. So i moved no more smog checks w00t</TD></TR></TABLE>
Oh ya... kinda forgot about that.
shbrown
Oct 10, 2005 03:06 PM
HONDA RR
Jun 6, 2005 11:19 AM
Luscious Lee
Dec 12, 2004 12:34 PM
EFin' Kyle
19
Aug 16, 2004 06:51 PM
weakGOODJunKieS.com
Sep 28, 2002 11:03 AM
