Wiring harness swap question
Alright i have a H22a4 sh and im about to order a obd1 h22a and i was wondering if i can use the sh harness? Do i need a a jumper or what?
Thanks man. So that would be my only choice is to do that? like there is no easier way to swap it? I wanna get rid of the atts, but dont wanna rig anything. I was just gonna see if i could use the whole complete obd1 h22a engine, tranny, dist., ecu.
the only other way is to mess with the distributor wiring. IMO, with the engine out, this is the easier way.
You can ditch ATTS as well, but you'll have a check engine light for the ATTS, and you probably won't pass an inspection scan, not sure on TN laws, but here in NC, that wouldn't fly.
The engine harness does not plug directly into the ecu.
Obd1 engine harnesses do not plug into obd2 cars at all.
You need to use the obd2 engine harness and oil pump and distributor setup as this is the only major difference between your current obd2 engine and the obd1 h22 you'll be putting in
The car has a piece of harness that goes from the shock tower (where the engine harness plugs in) down to the ecu, where it plugs in.
Your car will not pass an obd2 scan inspection with anything other than your obd2 p5m ecu that is in your car right now.
If you remove ATTS you may not pass inspection due to the light being on.
I don't mind helping out. It seems you're new to this thing. I appreciate that you're asking first and doing second.
There's no good reason I can see to not go ahead and change everything over.
Wiring it can be a bitch, as 98vtec. It is much easier and IMO a smarter decision to change over the hardware.
The only real investment will be $190 on an oil pump. So what. It could use it anyways most likely, not that they fail often, but it can't hurt.
Go obd1 if you must, but know that I've both been there and regretted it.
Yea i def understand where your coming from on. I was just thinking that would be the cheaper way. i dont wanna half *** anything or anything like that. Would it be better to go with the 97-01 h22a? lol sorry if i keep asking dumb question just trying to figure out what to do. Im gonna have to order something this thursday.
what about this? would that be my best alternative
http://www.jspecautosports.com...d=445
yes, that should work just fine, but I'd call them and make sure that the pickups and all are down at the crank on the 97-01 jdm engines just like they are on the USDM ones.
fwiw, you might be able to get your hands on an obd1 h22 and buy a new oil pump for less than the $1750 for that one.
Thanks alot for all your answers. I found a obd1 h22a longblock im gonna do, and use all my external parts so i can keep the obd2. I actually had a budget and now get to do the oil pump, timing belt, clutch, flywheel i want. and maybe a few dress up parts.
NotAJDMFanBoy
May 14, 2011 08:24 AM
redline870
Nov 9, 2008 06:11 PM
h22a_93accord
Apr 10, 2008 08:42 PM
