FS: Very Cheap 1998 Subaru Forester L Wagon, 5spd, AWD, 197k, Western New York
Old Mar 31, 2008 | 06:36 PM
SilverGT's Avatar
Default FS: Very Cheap 1998 Subaru Forester L Wagon, 5spd, AWD, 197k, $2500 Western New York
Well i have to get rid of my subaru forester so here is some information
5spd
197k
Runs, Drives, and Stop with no problem
Black with Gray Trim
Gold Painted Stock Wheels
Power Windows, Power Locks, Power Steering
Radio works
Decent Tires
Brakes all good
Suspension good
Air condition does work
Heat works
OEM Forester floor mats inclued and the rear trunk plastic liner
Cons:
-Small oil pan gasket leak
-Speedometer doesnt register [speed sensor]
-Exhaust leaks [gasket between muffler and midpipes]
I have listed all the problem and the price is as is. i will continue to fix the car so the if you want the car as is without those problem being fixed i can do it for $2500 but if i fix it the price will only go up.
Car is a great daily driver, I will have better picture up tomorrow. Let me know if your interested thank you
716 903 6606
David
Modified by SilverGT at 3:08 PM 4/2/2008
Old Apr 1, 2008 | 01:42 PM
SilverGT's Avatar
If anyone want i will trade this and my other 1995 Subaru legacy wagon LSi, Automatic, 218k also rebuilt at 200k. let me know thanks.
http://hondamarketplace.com/zerothread?id=2250670
Old Apr 2, 2008 | 02:09 PM
SilverGT's Avatar
Check engine light fixed, Bump for more pictures!!1
Old Apr 9, 2008 | 07:45 AM
92h22civichatch's Avatar
Default Re: (SilverGT)
no ones going to trade you a sol for this 163k rotted forester anyone who knows anything about suburus knows first the brake lines rot then the fuel lines then the fuel neck. also you left out all the important information has the coolant additive been done cause a bad headgasket on a ej25 is common and could be prevented by the additive. also there a know to have piston issues hows she sitting there? speedo didnt work speed sensor huh so that must mean 163k isnt accurate. oil pan leak better double check rarely its that usually its a rear main.
Northern California (Sales)
26
Jul 26, 2010 08:16 PM
chris1741
Jul 26, 2008 08:24 AM
SilverGT
Apr 9, 2008 07:37 AM
tecks2k
Sep 20, 2006 11:47 AM
