FS: 1991 Acura Integra 4 door db1 db one pieces red 16" rota gt3 hella good tires gsr tranny
Old Mar 31, 2008 | 12:22 PM
denraweb's Avatar
Default FS: 1991 Acura Integra 4 door db1 db one pieces red 16" rota gt3 hella good tires gsr tranny
PINK IN HAND!
Oh FYI for those who think these cars are heavy...my four door is about 50lbs heavier than a 2 door...and I can pull on that other white 2 door I have for sale
Trades that would interest me starting with what I want the most first would be:
-Lifted Jeep Cherokee 4 door with oversized tires must be 4x4, and have the 4.0l straight six motor. Must be 5spd...(No GRAND Cherokees, just laredos, etc..)
-Integra (DC)
-Bagged mini truck must be 5 speed...
Year: 1991
Make: Acura
Model: Integra GS-L
Milage: Don't know...when I got the car the cluster said 198,XXX. Lower mileage motor...
Title: Clean
Smog: Done
Price: $3,500 AS IS with a new b16 tranny or $3000 with GSR tranny or $2700 with gsr tranny and fat fives or $3000 with b16 tranny with fat fives.
Also can do payments...$2500 or $2000 down and the rest we can work out...
Interior: The interior is all black besides the seats and the head liner. This model was supposed to come with black leather seats, but were exchanged for some blue ones by the owner before the last. The two front seats have some tears on the *** part, and a few stains, but otherwise decent. Rear seats are still good. No tears. No cracks in the dash or anything. All black. Even black carpet from factory. Gauge cluster has amber bulbs, as well as the climate control. Climate control is getting a little light...needs to be redone.
Exterior: Clean shiny/glossy paint. There is I think two dents, but you can't really see 'em unless you are paying attention. Few minor paint chips, nothing really bad, and theres a long scrape mark on the trunk from the previous owner backing into a shopping cart. JDM One piece headlights. JDM Sidemarkers. Car sits on 16" Red Rota GT3's with 90% tires (Kuhmo Ecsta AST). NO CAMBER WEAR WHATSOEVER. Car was recently aligned as well. Dropped about 2.5"-3" or so on coilovers. Has a ball joint camber kit. Also has all 4 muduards, and EK sideskirts that are almost finished. Datum 1 rear tow hook, polished. Oh also the front bumper lights are wired as running lights and blinkers (kinda like 92-95 civic corners). The fog lights are also wired as stang alones (I guess you can say), you don't have to turn the headlights on to turn on the fogs. Bulbs in the one pieces are the JDM bulbs, I used the harness to run the JDM bulbs so I didn't have to cut anything up on the headlights.
Engine/Trans: Stock b18a1 motor, recently put in a lower mileage motor due to the old one spinning a bearing and bending a valve. Tranny is an unknown tranny with the stock clutch. It is a 90-91 Tranny, but not a stock one. At 80MPH it is at 3,750RPM in 5th gear. Grinds 2nd, 3rd, and sometimes 4th. But otherwise goes into gear perfectly fine everytime. Chipped PR4 ECU
The power antenna doesn't work due to the unit being messed up. The wiring works and everything, just the actual motor and unit needs to be replaced. I just leave the antenna up so I can listen to the radio sometimes.
The car does have an alarm as well, and will come with it. I will also install a kill switch if you want...very effective.
Here's some recent work done. Was done by me unless otherwise stated:
-New cam seals (done by Thong)
-Timing (done by Thong)
-Valve adjustment (done by Thong)
-New fuel pump
-Alignment (done by Louis Frame & Wheel)
-Brand new passenger side brake rotor (pads still good)
-Brand new axle with life time warranty
-Brand new alternator with life time warranty
-Brand new NGK Spark plugs
I will have pics up, but here's a few to hold it over until I get some more today...
RECENT PICS: CAR IS DIRTY 'cuz I'm lazy
Modified by denraweb at 11:25 AM 4/8/2008
Modified by denraweb at 11:05 PM 4/8/2008
Old Apr 2, 2008 | 02:46 PM
denraweb's Avatar
Default Re: FS: 1991 Acura Integra 4 door db1 db one pieces red 16" rota gt3 hella good tires gsr tranny (de
Bump!
Old Apr 3, 2008 | 08:20 PM
denraweb's Avatar
bump
Old Apr 3, 2008 | 08:48 PM
slowgd3's Avatar
bump cleann as hell
if only this was being sold next month
not getting insurance money till next month
Old Apr 3, 2008 | 10:13 PM
rexone's Avatar
Old Apr 4, 2008 | 07:25 PM
ITR1148's Avatar
pm'ed
Old Apr 8, 2008 | 10:24 AM
denraweb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowgd3 &raquo;</TD></TR><TR><TD CLASS="quote">bump cleann as hell
not getting insurance money till next month</TD></TR></TABLE>
Can also do payments!!
Bumpski!
H22HondaCRX
Sep 26, 2010 02:36 PM
denraweb
Northern California (Sales)
Apr 8, 2008 10:23 AM
G3NR8
Apr 24, 2007 07:43 PM
1h2nr
Nov 21, 2002 03:56 PM
