Power Steering Rack
I am having issues removing my old power steering rack & pinion to replace it. I have all of the lines disconnected and all of the bolts holding it to the sub frame removed so its just hanging by the steering column i just need some tips or some how to on disconnecting the steering column from the rack
go into the car under the dash. Look for the rubber boot that the steering column goes into and through the firewall. Remove the boot and you will see a pinch bolt holding the column to the rack. Remove the bolt and you should be able to separate the two.
Make sure you have the driver side tie rod end removed and the steering wheel turned all the way to the left. This will help when maneuvering the rack out of the subframe.
alright i figured the column out but there is one more stubborn bolt on the drivers side that won't loosen all the way and come out this is the only thing holding the rack to the sub frame any ideas..?
Its one of the four mounting bolts that hold the whole assembly to the sub frame but there are only 2 on the drivers side the ones on the actual control pump and its the bolt that is furthest away from the engine ??
yohimbine
Sep 12, 2013 08:49 PM
hatcht9x
Jun 29, 2008 01:45 AM
