obd-0 b18 w/HF harness
Just swapped an obd-0 b18a1 into a 1991 CRX HF using both the HF engine and chassis harness.
The Engine runs, but like ****!
Are there any plugs/sensors that need to be changed/added/deleted when doing this swap?
TIA
TIA
The dissy is you problem. The hf and si harness are diffrent. I did the same thing. I was swaping in a single cam. I just used the hf dissy and intake but you cant do that. you need to swap the under dash to si. or repin the dohc dissy to the hf wiring if you can idk. good luck those hfs are a MF
Were already running an obd-0 b-series dizzy.
So your saying that the plugs on the HF harness are different than the plugs on the b-series dizzy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akylem »</TD></TR><TR><TD CLASS="quote">The dissy is you problem. The hf and si harness are diffrent. I did the same thing. I was swaping in a single cam. I just used the hf dissy and intake but you cant do that. you need to swap the under dash to si. or repin the dohc dissy to the hf wiring if you can idk. good luck those hfs are a MF </TD></TR></TABLE>
DO NOT LISTEN TO THAT POST!!!
The HF and Si are the same as far as wiring.
So the HF harness should plug right into the obd-0 LS motor without any modifications?
No extra plugs needed?
We already have the motor running, but it doesn't run right. I'm just trying to make sure that I don't need to add any plugs..
^^^ also iac and iat are the same and easily mixed up. if it is an obd1 enging then u may need to advance the distributor alot and by that i mean past what the distributor notch allows. at least that is the case when i ran my d16z6 with a obd0 distributor. and what ecu are using? i hope not the hf one.... that would be a problem
peiku
Feb 21, 2006 03:10 PM
89 pos
21
Mar 9, 2005 09:47 PM
paulzy
Jun 21, 2003 03:34 AM
