"NEED HELP" why does my battery fuse(80A) keep blowing
Old Mar 31, 2008 | 01:40 AM
ahboii's Avatar
Default "NEED HELP" why does my battery fuse(80A) keep blowing
got a 94 civic ex coupe..just did motor swap(b18c1) n everything is done right but everytime i put a 80A fuse(battery fuse) it keeps blowing...right after i put on the positive wire to the battery.. SO I NEED HELP! WHAT COULD IT BE?
Old Mar 31, 2008 | 03:45 AM
JEGD16Z6's Avatar
Default Re: "NEED HELP" why does my battery fuse(80A) keep blowing (ahboii)
you need to check than re-check all your wires for a short.
Old Mar 31, 2008 | 03:57 AM
redcivic13's Avatar
that kept happening to my friend's car
but like what i did was i put the positive and took off the negative and then put the fuse then the negative iuno how it worked but it worked lol
Old Mar 31, 2008 | 05:20 AM
Luserkid's Avatar
Default Re: "NEED HELP" why does my battery fuse(80A) keep blowing (redcivic13)
Usually when it blows its because the white wire that goes to the alternator is not connected correctly. Double check that.
Old Mar 31, 2008 | 06:38 AM
ahboii's Avatar
yea man ill do that thanks if it dont work then ill let u know wats up
Old Mar 31, 2008 | 06:41 AM
ahboii's Avatar
Default Re: "NEED HELP" why does my battery fuse(80A) keep blowing (Luserkid)
yea i did that too n it work but then when i crack vtec a second later it blew up again n my car shut down soo i dont know haha
to REDCIVIC13
Garrett Maddox
Apr 7, 2016 08:14 AM
dakota1820
Honda Civic (2001 - 2005)
May 23, 2014 05:31 AM
1990AccordEX
May 18, 2006 05:09 AM
Cheeech
Nov 12, 2005 05:35 PM
horizongreyEJ1
Jan 15, 2005 10:03 AM
