Swapping the Acura Sign
Old Mar 30, 2008 | 10:21 PM
xlilninjax's Avatar
Default Swapping the Acura Sign
im asking this for my friend since he doesn't have an account. he wants to swap out the word "Acura" sign with Honda and the emblem as well. he was wondering if the holes and stuff are all the same. i think it is but he wants me to make sure. thanks for the help.
Old Mar 31, 2008 | 05:04 AM
JdmTypeRdc2's Avatar
The search buttom is your friend....
this topic has been covered hundreds of times on here and on Team-integra.net
When removing the acura sign, you will find 2 holes. The honda word emblem that you will be purchasing will not have holes, its strictly stick on. Make sure you align it so that it covers the holes.
as for the A emblem in the middle, that also have 2 holes and an adhesive back.
When purchasing an H emblem, depending on which one you buy, should be ok.
An aftermarket cheap one that you can buy for 15-25 bucks will not have any clips to fill the holes, it will just have an adhevise back so it just sticks on.
The real JDM ITR H emblem will have both the 2 clips, and the adhesive back.
Either one you buy will work since they will cover up the holes regardless...its just a question of whether you want to spend 20 bucks on a aftermarket one, or 50 on an OEM one. Thats completely up to you.....
there is your answer....
this time youre forgiven.....next time.....
SEARCH
Old Mar 31, 2008 | 07:32 AM
jhammond_82's Avatar
Reject Papi
Default Re: (JdmTypeRdc2)
wow, this i think is one of the biggest controversies on h-t. you could look on ebay for the emblems and they would probably have the adhesive back to them. its about the only way i know of to do that. or buy genuine emblems, but then your looking at spending big bucks.
Old Mar 31, 2008 | 08:10 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: Swapping the Acura Sign (xlilninjax)
The holes are the same on the "H" emblems, but the holes are different between the Acura and Honda name plate. Just trim the pegs off the Honda nameplate and use the adhesive backing that it has on it.
Or you can use the: <FONT COLOR="red"> SEARCH </FONT>
sup22
Aug 23, 2007 01:31 AM
Atlas
Aug 26, 2004 06:46 AM
Elemental
Mar 24, 2004 02:17 PM
IntegraT
Sep 17, 2001 09:17 PM
