How to get rid of bumble bee exhaust
Old Jul 9, 2002 | 09:15 PM
teg92's Avatar
Default How to get rid of bumble bee exhaust
My car never sounded like it until I had a spare cat modded into a straight pipe for occasional use. Obviously replacing the original cat will fix it, but I'm wondering if adding or changing a resonator for a bigger one will necessarily remove the bumble bee or not? TIA
Old Jul 9, 2002 | 09:31 PM
PnX-R's Avatar
Default Re: How to get rid of bumble bee exhaust (teg92)
I'm not too sure on it.. But I believe adding a resonator will take that noise away.. Or you could just add a glass pack..
Old Jul 9, 2002 | 09:43 PM
poison's Avatar
i used to run gutted cat, and straight pipe, and just a muffler, and had SERIOUS bumble bee.
i then failed emissions miserably, so i got a catgo high flow cat, that eliminated a lil bumble bee, but not all of it.
i recently got a glass pack resonator and sounds VERY nice. motor is much louder than exhaust, and exhaust sounds clean and muscly, even coming out of a 1.6l d16z6 pos....can't wait for h22
Old Jul 10, 2002 | 09:58 AM
eccentric.ek's Avatar
Default Re: How to get rid of bumble bee exhaust (poison)
run open header lol
Old Jul 10, 2002 | 10:10 AM
VTECorona's Avatar
Default Re: How to get rid of bumble bee exhaust (redUSDMhb)
A resonator will fix your problem.
Old Jul 10, 2002 | 10:56 AM
teg92's Avatar
Default Re: How to get rid of bumble bee exhaust (97RedTegGSR)
Should I add a resonator, or replace the resonator in my stock midpipe?
Old Jul 10, 2002 | 11:01 AM
junglistgsr's Avatar
my friend had that problem on his civic....he welded in a small glasspack as a resonator and it sounded MUCH better, sounded good actually. A nice thick deep sound with no buzzy annoying crap
Old Jul 10, 2002 | 12:06 PM
Mr. Softee's Avatar
Default Re: How to get rid of bumble bee exhaust (junglistgsr)
i run open header, all i have is this whirrling noise... not sure what it is... makes this pshhh sound like a bird chirping when i let off the throttle though. kidna annoyin
Old Jul 10, 2002 | 12:50 PM
owen_the_soyboy's Avatar
replace the testpipe with a resonated testpipe.
worked for me... sounded incredibly deep and rumbly, not raspy at all. (with an Apexi N1)
Old Jul 10, 2002 | 01:27 PM
Isaac's Avatar
New User
Default Re: How to get rid of bumble bee exhaust (94goldjungsr)
Deng it, your car is broken!
I hear that noise too all of the time, on Supra's, Z's, RX-7's, I think they all must have some major mechanical problems. Psshhhh.....(probably means the engine is going to die soon).
Old Jul 10, 2002 | 02:45 PM
zilverz's Avatar
Default Re: How to get rid of bumble bee exhaust (owen_the_soyboy)
where can i get this resonnated test pipe ?
and does this resonnated test pipe have glass pack in it ?
Old Jul 10, 2002 | 03:00 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: How to get rid of bumble bee exhaust (zilverz)
buy my RS*R
Old Jul 10, 2002 | 03:14 PM
zilverz's Avatar
Default Re: How to get rid of bumble bee exhaust (FuknGSR)
isnt that a complete catback ? i dont need the whole exhaust man .. got a greddy evo (;
Old Jul 10, 2002 | 03:21 PM
csufweed's Avatar
Old Jul 11, 2002 | 10:12 AM
teg92's Avatar
Default Re: How to get rid of bumble bee exhaust (csufweed)
Well, my car is way too loud as is right now. I'd like to ideally get rid of the bumble bee & quiet it down at the same time. Now would adding a glasspack achieve this or should I consider adding a different type of resonator?
Old Jul 11, 2002 | 11:47 AM
The Poopsmith's Avatar
Amen to that!
Old Jul 11, 2002 | 01:48 PM
teg92's Avatar
Old Jul 15, 2002 | 02:18 PM
zilverz's Avatar
I still have my buzzing like sound after installing my highflow cat ... the cat itself is resignator like shape ... but the Greddy Evo cat back pipe has a resignator as well ... should i just have that resignator (in the cat back pipe) cut and have a glass pack put in it ... will this defeat the performance increase from the highflow cat btw?
Old Jul 15, 2002 | 02:57 PM
neo1z's Avatar
that is the answer. its really funny though...i have a test pipe non-resonated and have no bee probs. oh well, ill take it.
Old Jul 15, 2002 | 03:14 PM
zilverz's Avatar
Default Re: How to get rid of bumble bee exhaust (neo1z)
Thats cool man ... but i need to fixxxxxxxxxxx mineeeeeeeeeeeee (: please tell me someone sells the resignated test pipe with glass pack or somethinggggggg i need linkzz people ... need to bring my tegraaa back from Limpinnnn to Pimpinnnn
Old Jul 17, 2002 | 10:31 AM
zilverz's Avatar
PLEASeeeeeeeeeeeeee help me kill these BEEZzzzzzzzzz hehe
i wanna keep a high flow style cat ... but need to muffle the beez nest! Straight Pipes less inclined to have the BEE tone then high flow cats ? i dont care.. ill put in a resignated straight pipe ... if you guys thing it will help .. i dont mind it being loud .. just the buzz kind of sounds raggidy at certain points
also as a side note .. ill do some of my own research... anyone know where i can find DIRECT fit straight pipes... i know http://www.testpipe.com anyone bought one of these and it fit perfect ? thanks fellas
[Modified by zilverz, 7:51 PM 7/17/2002]
Old Jul 17, 2002 | 02:36 PM
teg92's Avatar
I just fit a 24" glasspack in place of my stock midpipe.. here my conclusions.
- I need an aftermarket midpipe, because the stock one is a double piped piece of crap. The inside diameter of the actual pipe that flows exhaust gasses is probably 1 3/4 ID ...
- The glassback got rid of the bumble bee and made the car a CRAP LOAD quiter... But what I realized is that the bumble bee was actually caused from my motor. Ever since I swapped the head and put the header etc on, I noticed the intake had a mean growl from 2700-3200rpm, and since I put the gutted cat on, I couldn't hear it.. Well turns out I couldn't hear it because the exhaust was too loud. The bumble bee was actually that mean growl being audible on the exhaust side, which caused a bad vibration: bumble bee.
Old Jul 19, 2002 | 07:15 AM
zilverz's Avatar
can you tell you lost any performance puttin the glass pack in ?
Old Jul 19, 2002 | 09:40 AM
Hairy Gorilla's Avatar
Hey neo, What all do you have on your car. what is the differnet between resonated and non resonated?
4dr_Noob
19
Aug 19, 2012 11:45 PM
slazman999
Mar 14, 2010 03:21 PM
lude-tec
Jun 15, 2007 12:37 PM
93_teg_CT
Jun 20, 2005 07:58 PM
zcivicz
Apr 20, 2002 07:42 AM
