What ECU is better for my swap?
Old Mar 30, 2008 | 08:38 PM
90crxef's Avatar
Default What ECU is better for my swap?
I have a 1990 CRX with a LS B18A1 OBD0 swap, the motor is a 91. The guy i bought the car from has a P75 ECU in it right now and the harness is all sorts of messed up, but i just picked up a PR4 ECU and a new harness with directions to do it the right way, not spliting into other wires. So is the P75 or PR4 a better way to go with it?
Old Mar 30, 2008 | 08:50 PM
6KAOS6's Avatar
I would use the Pr4.
Old Mar 30, 2008 | 08:53 PM
Fern413's Avatar
Default Re: (6KAOS6)
your better off with the pr4 ecu...cuz thats the ecu for that engine....p75 is obd1
Old Mar 31, 2008 | 01:58 PM
90crxef's Avatar
aight thanks man, i guess i have some wiring to do tonight
Old Mar 31, 2008 | 06:57 PM
g2daturbo's Avatar
Default Re: (90crxef)
pr4 is the easy way to go, but the engine will make more power and have a higher redline if you convert to obd1 p75 what year is the ls you are installing???
Old Mar 31, 2008 | 09:16 PM
DC4Marco's Avatar
Default Re: (Fern413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 &raquo;</TD></TR><TR><TD CLASS="quote">your better off with the pr4 ecu...cuz thats the ecu for that engine....p75 is obd1</TD></TR></TABLE>
P75 is also OBD 2 as well.
https://honda-tech.com/zerothre...57564
Old Mar 31, 2008 | 11:04 PM
90crxef's Avatar
Default Re: (g2daturbo)
its a 91 B18A1. ive got it in the car and im tryin to get it started but for some reason it will turn over but wont actually start, i just bought a new distributor for it today and i had spark for a little bit and im not 100% sure cuz i just decided to call it a night, but im thinkin for some reason i dont have spark on the new distributor now too, just about ready to sell the thing cuz i dont have the time/patience to mess with it much more.
Old Apr 1, 2008 | 10:02 AM
90crxef's Avatar
Default Re: What ECU is better for my swap? (90crxef)
okay so i know theres really not much of a difference between the pr4 and the p75 ecu's i have. currently the p75 is wired up, but i noticed the head is pr4 on my b18a1, the guy was running a td-85u distributor and when i went to replace it i found the correct one was a td-23u so i switched em out, but im basically wondering if that obd2 p75 im running could be the reason behind my ignition timing issues on the PGMFI B18A1?
1xfastxhatch
Jan 24, 2008 10:29 AM
00CivicGirl
Nov 30, 2007 05:36 PM
BrainWashed
Jan 11, 2007 04:39 AM
B20inDCinLBC
Oct 27, 2006 12:44 PM
