Wheel bearing incorrect.. Swap?
Old Mar 30, 2008 | 08:30 PM
EkFG's Avatar
Default Wheel bearing incorrect.. Swap?
Okay heres what happen bad wheel on my 97 dx civic hatch replaced it. Went to parts store to buy the new one, THe first one i got they looked it up by year make model etc. When i went to replace it i found out that the one i taken out (the bad One ) was way bigger then the parts store had given me so i went back this time with the bad bearing to match the correct one. so for ***** and giggles i asked him to look up a 00 GSR wheel bearing and to pull it. Well the one for the '00 GSR matched to mine. so would that spindle be swaped with a Acura Integra spindle? if so would the brakes and rotors be from a '00 GSR???
Old Mar 30, 2008 | 08:39 PM
MasterShake's Avatar
sounds like they gave you the wrong bearing in the first place ( maybe a rear one?)
i believe the integra and civic wheel bearings have the same part number
Old Mar 30, 2008 | 08:41 PM
EkFG's Avatar
Default Re: (MasterShake)
no they are different
Old Mar 30, 2008 | 08:42 PM
EkFG's Avatar
Default Re: (EkFG)
wheel bearings for the rear are in hub sets and thats for drum or disk brakes
Old Mar 30, 2008 | 08:44 PM
look up the part numbers and see
Old Mar 30, 2008 | 08:46 PM
EkFG's Avatar
there different man i already did.
Old Mar 30, 2008 | 08:52 PM
EkFG's Avatar
Okay there is like 3 different options, i guess it readlly doesnt matter, Its fix but thanks.
Old Mar 30, 2008 | 08:54 PM
so you replaced the rear bearing with a 2000 gsr one in your 97 dx which has drum brakes?
Old Mar 30, 2008 | 08:55 PM
EkFG's Avatar
The one I picked out that worked was from a00 Gsr it has REAR disc Swap
Old Mar 30, 2008 | 08:57 PM
EkFG's Avatar
Default Re: (EkFG)
I never said i replace the rear wheel bearing. the rear wheel bearing comes in a hub set for the rear Which i was telling you because you said they might of givin me the rear one. i replace the front one with a 00' Integra bearing
Old Mar 30, 2008 | 08:58 PM
EkFG's Avatar
Default Re: (EkFG)
MasterShake
CVP|GARAGE
Online
7968 posts [100%]
Were better than you, SoCal
11-3-2005
Report this post to a ModeratorAdd this post to My NotepadSend Instant Message
« « » 9:39 PM 3/30/2008 Reply Edit
///Style
myspace.com/cvp_garage
SO-CAL IT HURTS MEMBER #3 (the hypeman)
CVP Garage
see thats what up said.
Old Mar 30, 2008 | 09:03 PM
Default Re: (EkFG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkFG &raquo;</TD></TR><TR><TD CLASS="quote">I never said i replace the rear wheel bearing. the rear wheel bearing comes in a hub set for the rear Which i was telling you because you said they might of givin me the rear one. i replace the front one with a 00' Integra bearing</TD></TR></TABLE>
yea thats why i asked, just trying to get **** clear
the front bearings are the same for a civic EX and GSR, that may be what you have
edit, theyre all the same (ex and dx). check autozone.com
Vladvyg
Honda Civic (2006 - 2015)
Jul 4, 2015 05:23 AM
eastbayrep
Feb 4, 2010 09:38 PM
suspendedHatch
23
Nov 25, 2009 12:50 PM
pgpunkguy
Feb 16, 2006 05:44 PM
akpsi
Oct 2, 2001 08:20 PM
