Civic Brake Splash Gaurd Question (VERY INTERESTING!!)
Old Mar 30, 2008 | 05:46 PM
stiffinEK's Avatar
Default Civic Brake Splash Gaurd Question (VERY INTERESTING!!)
i have seen 96-00 hatchie owners take out this civic brake splash gaurd (like puhuanas EK). its located right behind the rotors from your front and rear disc brakes. for more detail, its that metal plate that rounds off just like the size of the rotors.
http://www.hondaautomotivepart...82%29
Part number #16. (front disc)
http://www.hondaautomotivepart...SK%29
Part number #28. (rear disc)
Anyone with suggestions if taking this brake disc splash guard is safe for daily driving/ track? will it affect the brake system? will it cause less brake dust from it staining your wheels? will it cool down your brakes even more better?
any suggestions or thoughts or knowledge will be gladly appreciated.
Old Mar 30, 2008 | 05:55 PM
97Ej6mike's Avatar
I dont think it will have any effect on your brake system. Its merely a stock part to keep dust to a minimum.
Old Mar 30, 2008 | 05:59 PM
suspendedHatch's Avatar
Default Re: Civic Brake Splash Gaurd Question (stiffinEK)
Despite all the naysayers and doomsday prophets, I removed mine when I swapped Integra brakes onto my Civic many years ago, and my car hasn't blown up and the angel of death hasn't caught up with me yet.
It's possible it may help cool the brakes, but you're never going to know the difference. Are you going to run tests with a pyrometer to find out? I did it because it was easier than bending them back into place from sitting in my garage. They get bent and rub your rotors making an awful sound.
Old Mar 30, 2008 | 08:15 PM
EkFG's Avatar
It so no rocks and **** of that sort get sock between the caliper something like that if you remove it it would cool the brakes better but you also have a chance of getting rock stuck in there, its waht a friend told me he runs NASA and SCCA. Soim going by that
Old Mar 30, 2008 | 08:43 PM
MasterShake's Avatar
you can take it off to help the rotor disipate heat, but you run the chance of having the rotor damaged or, if splashed by cold water when its hot, cracked.
crazyhouse2011
Aug 29, 2014 08:00 AM
confliŠt
Honda Civic (2001 - 2005)
Nov 9, 2013 05:19 AM
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
lv6l
Dec 26, 2008 12:25 PM
