Prelude 89 SI H22A Swapped Thread
Old Mar 30, 2008 | 03:47 PM
jam89si's Avatar
Default Prelude 89 SI H22A Swapped Thread **Dyno update**
Hy guy's
Here's my setup!!
89 Prelude SI
H22A swapped
Head
Port&Polish
Camshaft Skunk 2 Pro 2
Skunk 2 Pro valve train (retainer, spring, cam gear)
Skunk 2 Pro Int.Man + Hondata gasket & 68MM T\B
OEM Honda head gasket
Block
Eagle H-Beam Rod
Mahle 11.5 comp Piston Stock bore
New bearing + Balanced crank
Unorthodox LightWeight Pulley kit
FGK Jasma Header
Custom 2.5 Catback
DriveTrain
M2B4 LSD Tranny
Bully Stage 3 Clutch
Custom Stage 1 axles
Fuel
STR Comp Fuel rail
Walbro 255 Fuel pump
RC 440 Injector
Susp/Wheels/Brake
Full Skunk2 Integra Coilover kit
SuperPro full Poly-U Bushing kit
Cross Drilled/Slotted Rotor + Hawk brake pad
Front Cusco strut-bar and custom rear
17inch Motegi DP6 + Falken Ziex 912
Going on the dyno in a week.
P28 on ECTUNE!!
Here's a couple of pics!!
Dyno update:
Dyno Sheet:
Vid:
Thanks for looking!!
Modified by jam89si at 11:16 AM 3/31/2008
Modified by jam89si at 11:48 AM 3/31/2008
Modified by jam89si at 11:22 AM 4/25/2008
Old Mar 30, 2008 | 03:49 PM
Hawkze_2.3's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (jam89si)
Kickass!
Old Mar 30, 2008 | 04:12 PM
95greenlude's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Kickass! </TD></TR></TABLE>
x2! i bet that thing scoots!!!
p.s. needs to be in ACC
Old Mar 30, 2008 | 07:47 PM
bubxba's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (95greenlude)
looks awesome.
Old Mar 30, 2008 | 08:09 PM
B20luda's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (bubxba)
Looks great man, cars clean too!! not many around, but im starting to see more and more now that AZ race came thru!!
Here is a picture of mine..
Old setup... 182/154
new setup/different car...excuse the engine bay, its been cleaned up/changed a bit since
Old Mar 30, 2008 | 08:37 PM
1funryd's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (B20luda)
I am so glad to see all the hard work that it took to get these done is now paying off.
Sean
Old Mar 30, 2008 | 09:32 PM
sup3rd's Avatar
omg so hawt
Old Mar 30, 2008 | 09:55 PM
no1knows908's Avatar
Default Re: (sup3rd)
Congrats man... that car is f-ing beautiful!
Old Mar 31, 2008 | 05:18 AM
jam89si's Avatar
Thanks boys!!
Dyno on thursday!!
Old Mar 31, 2008 | 07:31 AM
Televator's Avatar
Is there any cutting involved in this? That H is snug in there. Looks good clean though.
Old Mar 31, 2008 | 08:59 AM
snobordboy's Avatar
Moderator
wow those look gorgeous, I may have to start looking for a clean 3rd gen body, I always loved the ones id driven before.
Old Mar 31, 2008 | 10:43 AM
1funryd's Avatar
Default Re: Prelude 89 SI H22A Swapped Thread (Televator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator &raquo;</TD></TR><TR><TD CLASS="quote">Is there any cutting involved in this? That H is snug in there. Looks good clean though. </TD></TR></TABLE>
No cutting involved. This kit was done perfectly! The H22 drops in with no issues other than the crank pulley, and I am having that issue taken cared of with a new traction bar with a skip plate option.
Any questions then just hit me up at: onefunrydperformance@q.com
Putting it down for the 3GP Aftermarket!
Sean
http://www.1funryd.com
Old Mar 31, 2008 | 11:07 AM
jam89si's Avatar
And the crank pulley clearance issue can be solved with a Unorthodox LightWeight pulley kit like I've installed!!
1funryd I have to thank you again for those awsome mount!! Stiff like you can imagine!!!
Old Mar 31, 2008 | 01:59 PM
1funryd's Avatar
Default Re: (jam89si)
Your welcome! Let us know what your power gain is with all the work that was done to your engine.
Sean
Old Apr 9, 2008 | 06:19 AM
jam89si's Avatar
Dyno tommorow finnaly!!
Bad luck last week: The H22 Tensionner broke and I've bent a couple of valve in the head... Weve change all the Valves lastweekend and now everything is running fine!! But with an H23 tensionner!!
H22 Tensionner =
I'll post the result in the next days!!
Modified by jam89si at 7:26 AM 4/9/2008
Old Apr 9, 2008 | 07:12 AM
VTECepidemic's Avatar
that engine bay is &gt;&gt;.fooookin sexiness incognito.
Old Apr 9, 2008 | 09:02 AM
Apex1972's Avatar
Default Re: (VTECepidemic)
always liked the 3rd gens. very nice man. just replace your rusted bolts on the radiator support. looks great though.
Old Apr 15, 2008 | 05:37 AM
jam89si's Avatar
220 WHP and 165WTQ On pump 94 fuel!!
Rev's up to 8500Rpm!!
Video and pics soon!!
Old Apr 15, 2008 | 06:57 AM
GoldLudeRay's Avatar
in for numbers and vids that is some good power
Old Apr 15, 2008 | 02:57 PM
B18 Piston's Avatar
nice bro!
Old Apr 16, 2008 | 04:34 PM
Sir Kyle's Avatar
Default Re: (B18 Piston)
Love the Cusco strut brace man
Old Apr 16, 2008 | 08:55 PM
team123luder's Avatar
This is a huge inspiration...
Old Apr 16, 2008 | 10:35 PM
inspiration insmirashun... mario your a ****... you sexy *****.
arent you planning the h22 swap?
that would pretty much complete that sexy lude of yours.
Old Apr 17, 2008 | 06:07 PM
&lt;----------H22 inside already baby!!!
Old Apr 17, 2008 | 07:41 PM
Default Re: (team123luder)
wtf???? where have i been...
